2017 M8 road glide special - Road Glide Forums
 2Likes
  • 2 Post By Wood
post #1 of 4 (permalink) Old 05-17-2017, 01:09 PM Thread Starter
Thumbs down 2017 M8 road glide special
Inquiring to anybody had a problem with electrical failure, I was towed in all electrical failed motor kept running, turned around got home turned bike off, wouldn't shut off finally quit and then nothing, did have running lights but nothing else. Has 5500 miles, no engine or exhaust mods still all stock with the exception of a few chrome bolt ons. Harley shop has had it for 3 weeks and cant find the problem ...that's why I bought a new bike so I wouldn't have any problems, traded in a 08 road glide anniversary model that never failed me .......fuses and relays still had power and were good
cwh1009 is offline
post #2 of 4 (permalink) Old 05-17-2017, 04:38 PM
Thermodyne's Avatar
3 weeks on a new scooter in the shop, sounds like loaner time?
Thermodyne is offline
post #3 of 4 (permalink) Old 05-17-2017, 05:06 PM
Wood's Avatar
Find a new dealer. Something is really wrong with the dealer if they can't read an electrical schematic and isolate the cause of such a major problem.
Ohiobellboy and Swomack like this.
Wood is offline
post #4 of 4 (permalink) Old 08-13-2017, 08:49 AM
I have a 2017 RGU, my bike had a different concern with front brake rotors having run-out causing excessive vibration when using the front brake. The dealership would mic the rotors tell me the maximum run out is 8mm and my right front is at 9 mm lert front is at 6mm. Long story short they replaced the RF still had a brake vibration, they wouldn't replace the LF until I called the factory service representative from Harley Davidson. He requested the dealership to install two new front rotors new hardware and new brake pads. Perfect now. Call the factory service representative.
Jarrell is offline
M8 RG Ultra or M8 RG Special Lu *General Road Glide Discussions/Pictures 15 06-17-2018 10:57 AM
Upgrade a 2017 M8 107 Road Glide. What cam, push rods, and lifters make a good combo? dbravo11 Engine Related 3 03-17-2018 03:14 AM
2017 Road Glide 107" M8 Max Cell 818 cam crewchief25h Dyno Results 5 10-05-2017 01:35 PM
2017 Road Glide 107 M8 Wood WM8-777 cam fuelmoto Dyno Results 5 08-15-2017 11:57 PM
2017 Road Glide 107 M8 Wood WM8-222 cam fuelmoto Dyno Results 12 12-13-2016 07:53 PM
