Changed clutch cable to +6 cable...clutch does not appear to engage - Road Glide Forums
post #1 of 5 (permalink) Old 05-20-2017, 06:53 PM Thread Starter
Hello,
need some help, to confirm if I have a problem and some help to resolve, if I do.
I changed the clutch cable on a 2012 rgu, to accommodate new bars, all seemed to go fine, replaced oil, cable, adjusted cable, but was surprised that I couldn't move bike in gear with clutch pulled in.
I've read where this isn't an issue and is expected, but seem to think that prior ot cable change I could move bike while off and and in gear with clutch...so was thinking I had a clutch problem.
Before putting everything back together again + exhaust, can anyone tell if this is the case? Should I expect to be able to move the bike, engine off, in gear, clutch pulled in?
All feels, engine does turn over and start, it did creep on me a little but did not run away.
thanks!
backwaterdogs is offline
post #2 of 5 (permalink) Old 05-20-2017, 06:55 PM
Tailbreaker's Avatar
Yes, you should. Something isn't adjusted right
Tailbreaker is offline
post #3 of 5 (permalink) Old 05-20-2017, 07:25 PM Thread Starter
thanks! any idea where to begin? the ramp and 3 bearings all seem fine, clutch feels as expected
post #4 of 5 (permalink) Old 05-20-2017, 07:43 PM
If you're certain the ramps are engaging probably, I'd loosen the clutch and clutch cable and readjust per the Factory specs.
post #5 of 5 (permalink) Old 05-20-2017, 08:09 PM
MisterUSA's Avatar
I just did my bars and adjusted the new clutch cable (not hydraulic) on my 13 SG. Swagged it based on feel while in the garage. After the first couple of 'technical' runs to make sure the brakes worked, etc. I've had to adjust the clutch twice. Adding a bit more of a right hand turn (righty tighty, lefty Lucy) in order to adjust where the clutch engages. If you want the clutch to not 'drag" the bike with the grip fully engaged, you'll need about a full turn or two. Ride it and adjust to feel.
MisterUSA is offline
Fork Lock hard to engage christopherf *General Road Glide Discussions/Pictures 10 09-13-2017 11:48 AM
Starter spins but doesn't engage? Headrope Engine Related 13 06-01-2017 07:45 PM
Hp/TA appear low duane5157 Dyno Results 19 03-25-2015 03:44 PM
So how do bigger wheels handle and does rear need changed? kyle31490 Wheels and Tires 7 03-25-2014 09:52 PM
Can't seem to get photo to appear in my signature. fatboyO Forum Help Desk (Post Forum Issues Here) 1 05-09-2011 05:13 PM
