security light on speedo turn on by self - Road Glide Forums
post #1 of 2 (permalink) Old 05-21-2017, 12:06 PM Thread Starter
Question security light on speedo turn on by self
Hi new to board I just swapped out apes for new ones with PM controls and switches on 06 RG. when I turn it on. Security system turning on by self. shut it off with fob. push starter security system turn on again. also doesn't seem to run fuel pump when turning on and light that tell you to wait to prime does come on either. very thing worked before and have checked new wiring twice. any thoughts would be great or I guess it off to the shop. thx snackwolf
snackwolf is offline
post #2 of 2 (permalink) Old 05-22-2017, 09:54 AM
It' just a guess but you need to check the emergency stop switch on the right switch housing. If the stop/run switch isn't working right or it's in the off position the fuel pump will not run. Once you get the fuel pump to run the bike should start, if it still doesn't turn over then check your clutch safety switch in the left switch housing.
Electronic Security Alarm Flashing and Security Alarm Chirping When Ignition Switch I aklowrider Troubleshooting for Road Glides 2 05-03-2016 02:26 AM
Finding and resetting Security Codes and Bipassing Security RICKLB58 Troubleshooting for Road Glides 0 03-26-2016 09:41 AM
Auxiliary Brake Light/Running Light/Turn Signal Conversion Kit-69462-06A Subvet Parts for Sale 1 12-06-2015 06:40 AM
Bulbs for "N" light, bright light, and turn signals BILBO Lighting 7 01-25-2014 12:15 PM
HD security self install Qualuedtke Tech Area 1 05-11-2012 04:26 PM
