Help Please: Ignition / Power No Go - Road Glide Forums
post #1 of 2 (permalink) Old 05-29-2017, 03:12 PM Thread Starter
Skid_ro's Avatar
BLUF (Bottom line up front): Looking for some specific electrical help related to ignition and gauges.
I changed to 16" changing bars (I internally wired them with extended wire kit), new extended clutch and brake cables.
I have no power to my ignition, bars, or gauge cluster (no lights). No radio, turn signals, etc.
I do have power to my alarm (chirps) and initial stage of fuel pump (I believe it is the fuel pump). Nothing beyond that...
I have checked my ignition and ensured all pins are aligned, although I did have it out a couple of times. I have torn the bike apart more than once checking every plug, ground, etc. I have checked every fuse as well. Right now the bags, tank, seat, outer fairing, and gauge cluster are all back off of the bike.
Questions:
Would a broken or disconnected wire inside my new bars cause a complete blackout of my gauges and ignition?
Is it possible to have one tumbler out of sync, causing the split between alarm etc?
I am a total loss on this one. Anyone have some ideas for me? I was supposed to be riding in Rolling Thunder today - no so much... Bikes been down for four days now.
Thanks in advance.
Ron
2015 Road Glide Special
A work in progress....
Skid_ro is offline
post #2 of 2 (permalink) Old 05-29-2017, 08:51 PM
Questions:
Thanks in advance.
Ron
If your ignition turns in all positions and locks , it should be good. I recheck for crossed wire when installing the extension. Also check to make sure your pins are making contact in the plugs.
Some go Black Some go Chrome I go my way BACA POPEYE *General Road Glide Discussions/Pictures 66 06-21-2019 09:58 AM
No Sound Help please infernomd Audio 10 06-27-2014 11:46 PM
Please, Please, Please don't do this... cnidog Safety Area 13 09-01-2012 09:51 AM
Help please stalls no codes creed Troubleshooting for Road Glides 5 07-22-2012 08:08 PM
Ignition install please help!! raven006 Do-IT-Yourself 4 03-15-2010 02:47 PM
