Battery dies when trailering - Road Glide Forums
 12Likes
post #1 of 18 (permalink) Old 06-11-2017, 01:05 PM Thread Starter
Trailered my '16 FLTRU out to Colorado and battery died in the trailer on the way. Charged it and ran it all through the Rockies for a few days with no further issue. Trailered home and battery was dead again. The key fob was in the motor home with me on the trip out and in the glove box on the bike on the way back. Other than bad road Karma for trailering instead of riding, I'm fresh out of ideas. Anyone?
MDBrumley is offline
post #2 of 18 (permalink) Old 06-11-2017, 01:10 PM
The alarm probably kept going off on every bump you hit. This causing all the lights to stay on flashing your whole trip. Try leaving the key fob on the bike while trailering.
madmat, macabra11 and Little Wing like this.
post #3 of 18 (permalink) Old 06-11-2017, 01:23 PM
You need to disable your alarm system, if you did not do so. Turn ignition on, then off. Before red light goes out, press both turn signals; signal lights will flash once, release turn signal buttons; signal lights should flash 3 times showing system is disabled.
judgedelta is offline
post #4 of 18 (permalink) Old 06-11-2017, 04:26 PM
Transport mode
In owners manual it tells you exactly what to do when transporting
I unfortunately learned the hard way also
Hold on 7 is offline
post #5 of 18 (permalink) Old 06-11-2017, 05:37 PM
Trailer Karma
You hit right yourself! Any Road Glide in a trailer might create a bad karma. Now that is an lol, so please don't go off on me.
It was as always nice to get the answers as earlier posts covered.
MDBrumley likes this.
Drampy is offline
post #6 of 18 (permalink) Old 06-11-2017, 07:35 PM
JerseyGlide's Avatar
Transport Mode needs to be set. Every time you hit a bump while trailering it, the bike thinks it's being stolen & the lights will flash until battery is dead.
Work hard; play hard.
JerseyGlide is offline
post #7 of 18 (permalink) Old 06-12-2017, 12:11 AM
IdahoHacker's Avatar
Yup. Or just yank the main fuse.
2015 FLTRXS, SE Ventilator A/C, V&H Pro Pipe, S&S/Crane Chris Rivas Rocket 574 cams, Chris Rivas V-Twin dyno tune: 103 hp, 108 tq.
IdahoHacker is offline
post #8 of 18 (permalink) Old 06-12-2017, 05:12 AM
You just can't trailer some animals!!!!!!
dozer23 is offline
post #9 of 18 (permalink) Old 06-13-2017, 06:15 PM Thread Starter
Thanks for all the input. It looks like the concensus is transport mode. I'll go back through the owners manual cause I must have missed that page. Thanks again.
RGKen likes this.
post #10 of 18 (permalink) Old 06-13-2017, 06:30 PM
RGKen's Avatar
With Transport mode it disables the motion detection of the alarm and it will still not start without the fob. That way you will not have to worry about removing the fob from the bike every time you stop to eat. You will disable Transport mode as soon as you turn the ignition switch to on with the fob present. Just that easy.
2018 FLTRXS
RGKen is offline
Tags
battery , trailer
Trailering my Glide Rose2011 *General Road Glide Discussions/Pictures 41 01-16-2013 06:29 AM
got a trailering question? jeffb928 Aftermarket Accessories 4 06-29-2012 07:18 PM
Trailering Tiedown Points Ran8175 *General Road Glide Discussions/Pictures 11 05-21-2012 09:12 AM
Trailering Willy_B *General Road Glide Discussions/Pictures 5 05-06-2012 11:20 AM
Trailering suggestions please! mr4teth *General Road Glide Discussions/Pictures 27 06-08-2011 08:46 PM
