ABS Failure - Road Glide Forums
  • 1 Post By chromedome
post #1 of 7 (permalink) Old 06-14-2017, 08:42 AM Thread Starter
chromedome's Avatar
ABS Failure
So I'm out for a nice days ride when about halfway through the day the ABS light comes on and stays lit.
When I got home I read the DTC: C1023 Rear wheel speed sensor always equals zero...
I checked the wiring from the rear axle along the swing arm up into the ABS control module, all good visually. I reset the DTC and went for a quick ride. In short order the light was on and solid again.
Same DTC had been thrown. I have ordered a replacement sensor and am waiting for it to arrive.
Any thoughts on why an ABS sensor would fail without external damage?
Thanks...
2012 Road Glide Ultra (SOLD) & 2015 BMW R1200RT
chromedome is offline
post #2 of 7 (permalink) Old 06-14-2017, 09:32 AM
Thermodyne's Avatar
It's electronic, so it can fail.
With that said, issues with the wiring and wheel bearings are more common than failed sensors.
And the service procedure is to replace the bearing and sensor as a set. But I think that's about there being no sure way to determine which is at fault.
If you VOM is sensitive enough, or has a Hz setting, you can just connect to the sensor and see if it generates a signal when the wheel turns. If it does, then you'll need to check the circuit/harness
I've only ever seen one bad wheel sensor, and it had a brand new tire on it. Who ever changed the tire probably let it bounce off the floor. But I have seen a few dead wheel bearings set that code.
Thermodyne is offline
post #3 of 7 (permalink) Old 06-14-2017, 03:38 PM
Related in another way, your ABS will also fail if you don't change the brake fluid. Yours definitely sounds bearing or sensor related, but don't forget to change the fluid every 2 years also.
post #4 of 7 (permalink) Old 06-30-2017, 12:03 AM Thread Starter
chromedome's Avatar
Update
I installed the new sensor but the fault persists. I am still waiting on the ABS bearing to arrive.
My gut tells me (along with Thermodyne), that will solve the problem. The existing tone ring assembly was an add on to a non-abs bearing supplied with the after market wheel when purchased. It's a cheap plastic spacer that surrounds a small metal ring that all gets sandwiched between the fork and the wheel.
It looks like it froze in place after a couple years on the bike and stopped rotating to induce a signal in the sensor. I'm pretty sure a dedicated one piece ABS bearing will do the trick. I'll keep you posted...
post #5 of 7 (permalink) Old 06-30-2017, 07:39 AM
Thermodyne's Avatar
Do be careful when installing that bearing. It needs to be pushed in by the outer race. Don't hammer it, or push it by the center race.
post #6 of 7 (permalink) Old 06-30-2017, 09:50 AM Thread Starter
chromedome's Avatar
Thanks, I have the JIMS tool with a 25mm press
post #7 of 7 (permalink) Old 07-02-2017, 09:46 AM Thread Starter
chromedome's Avatar
New bearings installed. Problem solved.
RGKen likes this.
Can I put a Abs rear wheel on a non ABS rear? Louster47 Wheels and Tires 10 03-24-2013 10:05 PM
Question: Mounting ABS Wheels On A Non-ABS Bike MikeMan Wheels and Tires 10 02-22-2013 03:48 PM
non-abs wheel on abs bike W_D_R Wheels and Tires 1 11-24-2012 07:54 PM
To ABS or not to ABS apexlocator Safety Area 33 07-06-2012 09:17 PM
Bonding ABS to ABS or fiberglass? Monkeyman Paint & Bodywork Section 8 04-28-2012 02:16 PM
