Security Alarm Died - Road Glide Forums
post #1 of 3 (permalink) Old 07-21-2017, 08:15 PM Thread Starter
woverby's Avatar
Send a message via Skype™ to woverby
Security Alarm Died
So, I was leaving work this evening and thought, wow what a great evening for a ride. Unfortunately when I turned on the ignition my alarm went off rather than the ignition. I had my FOB with me so used the PIN security override and rode home instead.
At home I tried the other FOB, same thing. I also checked for DTCs, and there were none. I replaced the 4-month old battery in one of the FOBs, same thing.
Since the bike is under warranty, I will take it in to be fixed. Just a pain because of the time involved to get this fixed.
That said, I have two questions:
1) Has anyone else had their security system fail on a new bike?
2) How can I permanently disable the security system (not use the PIN each time), until I get this fixed? The owner's manual doesn't help.
Thanks all...
2017 FLTRU
Colorado Springs, Colorado
woverby is offline
post #2 of 3 (permalink) Old 07-21-2017, 10:05 PM
skratch's Avatar
the systems fail rarely. more than likely, you've got something else going on. did you put the battery in correctly? upside down is common.
you can't. I usually let my battery run down completely before I replace it. if you use the code a few times, you can get to the point where you can punch it in super quick and is relatively painless.
Thanks all...
skratch is offline
post #3 of 3 (permalink) Old 07-21-2017, 10:47 PM Thread Starter
woverby's Avatar
Security System Failure
Originally Posted by skratch View Post
I double checked the battery. It was installed correctly, but the new battery came with paper over the negative terminal that I did not noticed when I swapped it out. Security works now. Still weird how the 2nd FOB didn't work, but now both work.
We had our usual Colorado Monsoon afternoon shower, so my bike was wet. Don't know if that made a difference.
Thanks for the help.
2017 FLTRU
woverby is offline
Electronic Security Alarm Flashing and Security Alarm Chirping When Ignition Switch I aklowrider Troubleshooting for Road Glides 2 05-03-2016 02:26 AM
Finding and resetting Security Codes and Bipassing Security RICKLB58 Troubleshooting for Road Glides 0 03-26-2016 09:41 AM
Could Not Shutdown Security Alarm Phantom6722 Troubleshooting for Road Glides 5 05-15-2014 02:12 PM
Security Alarm Pager tip. r0de_runr Do-IT-Yourself 10 09-29-2013 09:02 PM
Battery died, now speakers not working!!!!!! schnid72 Audio 11 02-12-2011 07:33 PM
