Red Voltage Light - Road Glide Forums
post #1 of 6 (permalink) Old 08-01-2017, 02:22 PM Thread Starter
SoCal96R's Avatar
Red Voltage Light
While riding my 2015 FLTRX, the red light in the voltage instrument panel came on and voltage reading went to about 12 volts. Voltage is usually just above 14. Bike cranks up fine, rides fine, no unusual noises that I can hear. Put bike on tender while I was on 2 week vacation. Took off tender, cranked up, no red light but voltage at 12, went for short ride. Five minutes later, red light came on. Everything works as far as I can tell. Any suggestions would be appreciated before I decide to take her in.
SoCal96R is offline
post #2 of 6 (permalink) Old 08-01-2017, 02:35 PM
Dragon Dude's Avatar
2013 RGC, my voltage will drop to almost 10 volts and will stay there till i'm up and running and then all of a sudden it will just jump up to 14+. It's been doing this for a while now. I am going to replace my voltage regulator with a better aftermarket one soon.
Dragon Dude is offline
post #3 of 6 (permalink) Old 08-01-2017, 06:05 PM
Thermodyne's Avatar
Use a VOM or other external volt meter and check the voltage. Check it with engine off, then engine running @2000 rpm. 12.6 and 14.5 are what you'd be looking for + or - a few 10ths.
Sounds like a regulator, but could also be a stater. You can check the stator output at the plug with a VOM set to AC current. Not sure what the spec is for a 15. The older ones were 32-46 volts ac.
Thermodyne is offline
post #4 of 6 (permalink) Old 08-02-2017, 09:49 AM
You should check all of the major electrical connection first but I would guess that the Voltage Regulator is the problem. If the stator is bad the voltage will be normal at cold start up but as the bike warms up the voltage will drop and eventually the voltmeter will read around 10 volts.
post #5 of 6 (permalink) Old 08-02-2017, 05:24 PM
battery cables
check battery cables first......that's usually the problem.
billbeemer is offline
post #6 of 6 (permalink) Old 08-02-2017, 06:22 PM Thread Starter
SoCal96R's Avatar
Decided to take her in to the dealer. I was pleasantly surprised to learn that the stator had burned out and would be replaced under warranty.
SoCal96R is offline
Voltage drop= check engine light Masterchiefmike Troubleshooting for Road Glides 3 07-31-2013 06:36 AM
Voltage meter reads zero and red light RoadGlide0611 Troubleshooting for Road Glides 3 05-17-2012 05:32 PM
Red Bulbs for Gauges that will stay Red jimmyray11349 *General Road Glide Discussions/Pictures 10 11-02-2011 10:56 AM
Colors Crimson Red Sunglo vrs Sierra Red Defy *General Road Glide Discussions/Pictures 10 04-10-2011 12:31 PM
Kansas allowing motorcycles to run red light if it doesnt change. DED HD *General Road Glide Discussions/Pictures 15 02-24-2011 10:33 AM
