electrical issue - Road Glide Forums
 2Likes
post #1 of 15 (permalink) Old 08-07-2017, 09:49 AM Thread Starter
sfcusaret2004's Avatar
electrical issue
Well I guess you learn something new everyday. As I was riding back from Alabama the other day I went to honk my horn at a cager that was encroaching into my lane, ( I know, never happens right?) That's when I discovered that my horn wasn't working anymore (WOLO bad boy horn, purchased and installed 3 months ago). No biggy, Just rode through a torrential downpour so I thought perhaps the connection had gotten wet. Avoided the car and pressed on. Went to switch lanes and found that my blinkers weren't working either. Getting better and better. Tried the flashers - nope nothing there either. Well this sux, but I can still use hand signals right? OK get out of the city and go to set the cruise and nothing, nada, ain't happening. OK this is starting to get concerning as I still have 400 + miles to go, it's getting dark and I'm wondering what's gonna go next. I look at the fuel gauge and figure I've got another hundred miles or so so I decide to press on. Nothing else pops up so here I am riding a 13 road Glide Ultra with no horn, no blinkers, and no cruise. I'm trying to figure out what all three of these have in common and I can't figure it out. I stop for gas and discover that the brake light is gone as well. Crap! I still have headlights, tail lights, running lights, ignition and accessory power. the radio and associated systems are still functional so I decide to press on to the stop for the night in Dayton. I pull out the service manual at the hotel and think I figure out that it could either be the HFSM/TSSM, or almost anything else! I convince myself that it is the TSSM/HFSM and decide to get it checked out first thing in the am at the nearest dealer. At 930am I pull into Buckeye HD in Dayton and see that they don't open until 10. Crap! I try the door to the service area and it's open so I go inside to see if anyone's around. I run into a guy,m explain my predicament, that I'm passing through and want to get the bike checked out. "No Prob." he says, "I'll go get a service writer and we'll figure it out." Sweet! The shop isn't even open but they're willing to help me out. Long story short, turns out not to be the TSSM/HFSM but a 1.50 fuse. They only charge me for a half hour (standard rate for troubleshooting is 1 hour), replace the fuse and tell me that its the F*^king horn that is blowing the fuses! I leave it disconnected until I get home and hit the road. No further issues.
So, the take away from this adventure is Kudos and props to Buckeye HD for taking excellent care of a traveler and a big FU to WOLO Horns for their piece of crap, over priced horn!
reds4 likes this.
sfcusaret2004 is offline
post #2 of 15 (permalink) Old 08-08-2017, 07:23 AM
Nice to hear a good story about a HD dealer. Glad to hear that your bike is fixed and that it wasn't anything serious.
post #3 of 15 (permalink) Old 08-08-2017, 08:17 AM
Did they say WHY the horn is blowing the fuse? Do you need to run its own inline fuse in order for it to function properly?
macabra11 is offline
post #4 of 15 (permalink) Old 08-08-2017, 09:17 AM
twowheeladdict's Avatar
Did you wire up that horn through a relay? That horn draws too much power to be plugged into the OEM horn circuit on most bikes.
Plus, those pocket air horns have to be protected from the rain.
twowheeladdict is offline
post #5 of 15 (permalink) Old 08-08-2017, 09:34 AM
jcarruth's Avatar
That horn draws 18 amps! It needs to be fed from a fused lead from the battery through a relay that is controlled by the stock horn circuit. I would use 14ga wire.
I attached a generic diagram. Substitute the green wire for your (+) #86 horn switched lead and the (+) #87 output from the relay to your (+) terminal on the horn. Negative horn switch wire goes to terminal #85
I have a Wolo Bad Boy on my KLR and have never had any trouble with it. The key is to mount it with the horns facing down so they will drain. The thing is loud as hell.
2017 HD Road Glide Special
jcarruth is offline
post #6 of 15 (permalink) Old 08-08-2017, 05:28 PM Thread Starter
They said it was drawing too much power, but I recently upgraded to the high output stator and alternator. Also I have had the horn on the bike for about 3 months and never had a problem. When I got home, I disassembled the horn as best as I could and found out that one of the wires on the winding had broken loose. Not sure if that caused a short or not but, the cheap plastic cover was coming off anyway and vibrating so I'm not really happy with the quality of the horn either. Either way, I haven't had an issue since switching back to the original horn, other than it sounds like a six year old whispering in the dark! Anyone know of a good, cheap, LOUD replacement for the stock unit?
post #7 of 15 (permalink) Old 08-08-2017, 05:32 PM Thread Starter
twowheeladdict " Did you wire up that horn through a relay? That horn draws too much power to be plugged into the OEM horn circuit on most bikes.
Plus, those pocket air horns have to be protected from the rain."
No I didn't wire it through a relay as the instructions said it was a plug and play unit.
jcarruth That horn draws 18 amps! It needs to be fed from a fused lead from the battery through a relay that is controlled by the stock horn circuit. I would use 14ga wire.
Thanks for the info
post #8 of 15 (permalink) Old 08-08-2017, 05:48 PM
Thanks for the info
Based on these two responses it is apparent that you don't know a lot about electrical circuits. Either take some time to learn or leave to the professionals and enjoy riding instead of breaking down.
post #9 of 15 (permalink) Old 08-09-2017, 06:49 AM Thread Starter
Yea, twowheel you're right, I don't know shit about electrics but when I buy a product that says it's plug and play, I kinda expect it to be just that. If it had said "needs a degree in electrical engineering and an awesome set of tools to install." I would have passed. Usually folks on here are a bit more accommodating but I guess someone pissed in your cheerios this morning? I don't believe I said anything in my previous posts to deserve the "learn or leave it to the professionals" comment but what the hell, Thanks for the advice, I'll keep it in mind.
reds4 likes this.
post #10 of 15 (permalink) Old 08-09-2017, 07:21 AM
Sorry I ruffled your feathers. I stand by my statements though, and didn't realize I needed to say it more delicately.
To answer your horn recommendation. There are no horns that will be louder than stock that don't pull more amps. To achieve more sound requires more power. You are lucky the fuse blew. Some guy have replaced the stock fuse with one that handles a higher load and ended up melting wires and horn switches.
Head unit or other electrical issue? L-Premo *General Road Glide Discussions/Pictures 1 10-30-2013 10:02 PM
Electrical possible sensor issue...??? Johnzz1420 *General Road Glide Discussions/Pictures 5 08-05-2013 04:31 PM
2012 RoadGlide Ultra Electrical Issue H-Town Defender Troubleshooting for Road Glides 1 07-01-2012 11:38 AM
Electrical issue ? tcon287 *General Road Glide Discussions/Pictures 1 09-05-2011 09:51 PM
Electrical issue with horn and left blinker mtmy2k Troubleshooting for Road Glides 3 09-03-2011 10:56 AM
