annoying squeak - Road Glide Forums
 9Likes
post #1 of 22 (permalink) Old 08-07-2017, 10:43 AM Thread Starter
Thumbs down annoying squeak
I tried searching and was unable to locate any answers.... sorry if I missed it. But I bought a 2015 Road Glide Special an just put 2k miles on it. bought it with 7400. Lately I've noticed a loud distinguishable squeak/chirp which sounds like its coming from the front end when I go over moderate bumps or bigger. any ideas what the culprit could be? sounds like its coming from the front inside the fairing or handlebar clamp area.
klong1038 is offline
post #2 of 22 (permalink) Old 08-07-2017, 11:33 AM
I was going to say , lube your exhaust slip-on bracket where it slips into the rubber grommet, but that's in the rear.
Doug06rg likes this.
post #3 of 22 (permalink) Old 08-07-2017, 12:53 PM Thread Starter
I already replaced them, cheap and easy so I gave it a shot. didn't change. Thank you
post #4 of 22 (permalink) Old 08-07-2017, 01:53 PM
DED HD's Avatar
heat shield clamps?
'10 Red Custom:
DED HD is offline
post #5 of 22 (permalink) Old 08-07-2017, 02:04 PM
turbochrisb's Avatar
Exhaust related would be my guess.
turbochrisb is offline
post #6 of 22 (permalink) Old 08-07-2017, 03:00 PM
jcarruth's Avatar
Check your gas cap door. I isolated my noise issue there on my '17 RGS.
2017 HD Road Glide Special
jcarruth is offline
post #7 of 22 (permalink) Old 08-07-2017, 03:13 PM
SteadyEddie's Avatar
There is a Nob on the left Hand Grip for the Volume of the Radio..........turn that all the way up.
SteadyEddie is offline
post #8 of 22 (permalink) Old 08-07-2017, 03:20 PM
DE-Glide's Avatar
I am currently in the process of eliminating squeaks and rattles in my front end as well. The squeak/chirp you are hearing might be where the cowbell meets the plastic body colored trim piece. I've just taken this apart as well as the gauge cluster and added weather stripping to areas and have applied a thin layer of cloth tape to wherever two hard surfaces meet. (Like where the gauge cluster surround mounts to the fork legs) So far this has eliminated a good bit of this. Another culprit was actually the small chrome plastic piece beneath the fork lock. It clips into the gauge cluster and is a plastic on plastic connection. The two of these rubbing together was a "rattle point" for me as well.
Ride More, Work Less
DE-Glide is offline
post #9 of 22 (permalink) Old 11-05-2017, 06:17 AM
Iíve been dealing with a similar squeak thatís been driving me crazy for a couple of months. Sounded like it was coming from front end, perhaps forks. Was often able to hear it when getting on bike and just tilting it upright off kickstand, however, pushing down on bars was hit or miss. Slight road imperfections nearly always caused the squeak. While I was gettIng ready to store the bike for the next month or so I happened to just press on the front left side of my Lepera seat and sure enough, the squeal was heard. Took the seat off and squeal was completely gone. Iíll soon locate where itís rubbng and eliminate what was once a very annoying issue.
RomFree likes this.
ccdd1234 is offline
post #10 of 22 (permalink) Old 11-05-2017, 07:39 AM
gorillaman's Avatar
Front end noise
So.... every time I would enter my driveway or a curb into a plaza, the front end made a creek, clang noise...
I ended up having to adjust my front steering bearing. The swing was too loose.
just a thought.
2016 FLTRU Vivid Black
gorillaman is offline
Annoying squeak! Nordic Berserker *General Road Glide Discussions/Pictures 11 05-18-2015 08:56 PM
squeak/squeal from rear palmpalm *General Road Glide Discussions/Pictures 9 09-24-2012 10:32 AM
Annoying Fuel Spray Timinfla2 *General Road Glide Discussions/Pictures 43 05-14-2011 12:56 PM
2011- Fixed annoying squeek Lama Road Glide Specific Discussions 1 10-16-2010 09:25 PM
Annoying clunk/rattle over bumps from front end GizmoGlide *General Road Glide Discussions/Pictures 17 04-01-2010 03:15 PM
