fuse ? - Road Glide Forums
post #1 of 10 (permalink) Old 11-28-2010, 01:06 PM Thread Starter
fuse ?
Need assistance....my 2006 road glide is blowing the 15 amp accessory fuse, any ideas?
glideon is offline
post #2 of 10 (permalink) Old 11-30-2010, 03:37 PM
PGR
PGR's Avatar
Do you have anything plugged into the accessory plug under the seat? If not, make sure the rubber boot is in the acc plug. You may have picked up a chunk of something in the plug causing a short. Check for crimped or smashed wires. I think the brake light is also on that fuse... but not sure.... so check that wire too.
And try setting the acc switch to off to see if the fuse holds.... I should have said that one first.
Ron..........................
PGR is offline
post #3 of 10 (permalink) Old 11-30-2010, 04:30 PM
Dead Bird Dog's Avatar
You probably have a crimped wire somewhere....get a circuit breaker to replace it until you find it. Makes things a lot easier than going through a couple boxes of fuses. I replaced all of my fuses with CB's after dealing with a similar issue a few years ago.
1998 95th Anniversary Road Glide (#161)
"We sleep safe in our beds because rough men stand ready in the night to visit violence on those who would do us harm."
-George Orwell
Dead Bird Dog is offline
post #4 of 10 (permalink) Old 11-30-2010, 04:45 PM
mrbill's Avatar
Done any work, changes lately? That is usually the 1st place to look.
mrbill is offline
post #5 of 10 (permalink) Old 12-08-2010, 11:33 PM
Ducflames904's Avatar
Look for chaffed wire. Maybe between the fairing and the cluster on the bars
Ducflames904 is offline
post #6 of 10 (permalink) Old 10-10-2012, 09:27 PM Thread Starter
blown fuse
I found out why my bike was blowing fuses, the cigerate lighter rubber seal was torn and makeing a short and blowing the fuses
glideon is offline
post #7 of 10 (permalink) Old 10-10-2012, 09:34 PM
Triplej's Avatar
Wow that was quick
Triplej is offline
post #8 of 10 (permalink) Old 10-10-2012, 09:58 PM
RufusBarkley's Avatar
Originally Posted by Triplej View Post
Wow that was quick
I'm picturing glideon stripping his 06 down to the frame to find that short.
Give the man credit for persistence.
Me personally, I would have given up after a year
Just goes to show,sometimes it's an easy fix......
Sedona Orange FLTRX 103.
79 Shovel Chop.
RufusBarkley is offline
post #9 of 10 (permalink) Old 10-10-2012, 10:14 PM
ShitHouseRat's Avatar
You guys are a riot!
ShitHouseRat is offline
post #10 of 10 (permalink) Old 10-10-2012, 11:13 PM
Phantom6722's Avatar
A good reason to stop smoking and throw the ligther away.
Cheers Skip
Phantom6722 is offline
Heated Gear - Fuse Question RGUltraRider Aftermarket Accessories 23 02-08-2018 08:23 AM
Keep Popping Fuse MoosesUltraGlide Lighting 9 02-03-2012 08:04 PM
Heated Gloves - Fuse Question jober Clothing 3 01-24-2012 01:28 AM
Which fuse for the cig lighter... jupiter Troubleshooting for Road Glides 6 04-08-2011 10:38 AM
40 amp main fuse twowheel99 Do-IT-Yourself 4 03-05-2011 06:55 PM
