Oil spraying out of Air Cleaner? - Road Glide Forums
 12Likes
post #1 of 18 (permalink) Old 10-27-2017, 11:04 AM Thread Starter
wprvresort's Avatar
I am the first to admit, I am a moron, I know nothing about engines, and I am also fat. Okay, that is all done with.
I am attaching a couple of pictures of what I am seeing. Oil is apparently spraying out of my upgraded (Arlen Ness) air cleaner. I would like to know why and what can be done as I do not like being sprayed with oil and if my wife were on the bike when it happened.....well, I would not be typing this as I would not have the bike.
I did take it to Harley but was told to go away as it will NOT BE COVERED UNDER WARRANTY since I have a Arlen Ness air cleaner and Vance and Hines exhaust. Will be posting this in another thread.
Any advice, help, or just words of wisdom is greatly appreciated....about the bike....not that I am fat.
koryu2u likes this.
wprvresort is offline
post #2 of 18 (permalink) Old 10-27-2017, 11:29 AM
twowheeladdict's Avatar
Have you checked the engine oil level?
Who installed your aftermarket air cleaner and exhaust?
twowheeladdict is offline
post #3 of 18 (permalink) Old 10-27-2017, 11:32 AM
jchar27's Avatar
Most of the time I've heard this is due to having too much oil.
Find a new dealer. The right dealer will treat you right.
2018 CVO Road Glide, Black Earth/Vivid Black
Fuel Moto Road & Track 2 into 1, Fuel Moto custom K & N Air Cleaner, Redshift 468 cam, Power Vision.
2003 Super Glide 100th Anniversary Edition
jchar27 is offline
post #4 of 18 (permalink) Old 10-27-2017, 11:37 AM
Thermodyne's Avatar
M8 with a stage kit?
Blowing oil out the breather. If it's not the seal rings where the breather bolts up, then it needs to be brought to the MoCo's attention. The oil pumps are not holding up. And some are sumping badly.
Thermodyne is offline
post #5 of 18 (permalink) Old 10-27-2017, 11:49 AM
Swomack's Avatar
It is usually caused by the oil being over filled.
When the motor is hot the oil will expand causing your issues.
Check the oil level and make sure theres not to much in there.
Swomack
BlueBagger12 likes this.
My Gallery / Click Below Link
Swomack is offline
post #6 of 18 (permalink) Old 10-27-2017, 11:59 AM
DanHappy's Avatar
The air cleaner is the problem. Lots of people take the spent oil that gets pulled into the motor to be burned off, and pipe it to the ground to drip or a catch can. sometimes the filter element is too free flowing. The stock filter is not as free flowing, so no problems. I am also a member of HS Forums. Here is the link to a discussion there.
https://www.hdforums.com/forum/milwa...n-your-m8.html
Welcome to the site too BTW.
koryu2u likes this.
DanHappy is offline
post #7 of 18 (permalink) Old 10-27-2017, 12:04 PM
DanHappy's Avatar
... and now..
madmat likes this.
DanHappy is offline
post #8 of 18 (permalink) Old 10-27-2017, 12:29 PM
calgaryglide's Avatar
Couple things to consider;
1. Too much oil in the sump. The oil capacity listed in the owner's manual and the service manual is for a dry motor. I don't care how careful you are or what type of suction you use, you will never drain all the oil out of a motor during an oil change on any vehicle. There are too many nooks and crannies for the old oil to hide in, even with a warm motor and old oil flowing out like thin hot maple syrup, some will be left behind. Best guess is between 1/4 to 1/2 of a quart (I work in metric so 250-500ml). When performing a "hot oil change" never ever put the full amount of oil back into the motor. Reduce that amount show in the operator and/or service manual by 1/2 quart to begin with. Start your motor, let it warm up to circulate the new oil, ride it even for a short distance say a mile or so and come back. Shut off the bike, park it on the jiffy stand, protect your hand and remove the dipstick and check the oil level. It will most likely be in the middle or bottom third of the "OK" zone shown on the dipstick. You will not be running under the required amount of oil. It is all there. Some of it is trapped in places that cannot be accessed easily
2. Bad breather bolt system. You will have to take off your air cleaner and inspect the breather bolts, remove them to inspect them. Clean them, make sure there are no blockages. Check the o rings, on some air cleaners there are two/bolt on others only 1 per bolt. Are the o-rings in good shape? Replace any that are flattened/cut/torn. Lastly apply a vacuum or suction to the breather bolt holes in the head, DO NOT BLOW AIR INTO THEM. Only apply mild vacuum to pull out any possible "clots". This is another area where oil can and will accumulate over time in those "nooks and crannies"
3. Oil quality and multiweight. I am sure you are using a quality oil, and I am sure you are using 20W50 multiweight oil. When you change oils on the road do you use the same brand of oil, do you use the same multiweight formulation? I hate to sound like a bad Quaker State advertisement but "not all oils are the same". Many dinosaur oils have different sources from different regions and formulations can change depending on where the oil was produced. All oils must pass testing but variations in formula can all pass the same tests. Most synthetic or chemically composed oils are made in one place, for the most part, therefore consistency is usually much better. Harley Syn 3 oil as well as Harley dinosaur oils are shopped around to the lowest bidder. Suppliers can change over time for their branded oil. Again all the oils meet the testing, but do they meet or exceed? My point here is be consistent, use the same oil brand all the time. You can change the multiweight formulation depending on the season and your type of riding but choose a reputable brand and stick with it. Many of us use an aftermarket synthetic oil that we trust, Redline, Royal Purple, Amsoil to name a few. I prefer to stay away from the common big brand oils such as Mobil 1, Castrol or Quaker State. They may make great oils but they are also diversified and have several locations/refineries/chemical plants that serve regions of North America. Their oils will meet the standardized testing but their formulation between plants can and often are tweaked depending on their source oil.
In conclusion, don't over fill the engine oil sump, in fact let it run in the lower portion of the checkered area on the dip stick. Maintain your air cleaner breather bolt system. Use a consistent high quality oil that meets and exceeds the requirements of your motor and change the oil often, with smaller than suggested intervals especially when touring longer distances and having your motor run at consistent rpms for long periods of time (interstate riding). Cheap oil is cheap, good oil is more money but oil is the blood of your motor, freshen the blood more often and it will pay off with a motor that lasts longer and runs stronger. If you cheat your motor, it will cheat you out of longevity.
Those are my thoughts and practice and not necessarily the thoughts and practice of anyone else but I have never had to replace a motor in any of the vehicles in my fleet. I run GM, Dodge, Jeep, Fiat, Ford, Honda, Arctic Cat and Harley Davidson among my personal and company vehicles.
Calgaryglide
calgaryglide is offline
post #9 of 18 (permalink) Old 10-27-2017, 05:34 PM Thread Starter
wprvresort's Avatar
I had Harley do the oil change and they used their synthetic. I checked the oil a few days ago and it was about a 1/2 Quart shy of full. (checked hot on jiffy stand)
I did the install on exhaust and air filter. This particular air filter blocks the holes where the breather bolts were so there is not supposed to be any leaking or runoff.
The bike does have the stage IV upgrade and the new sump was installed.
post #10 of 18 (permalink) Old 10-27-2017, 08:06 PM
eddienelson's Avatar
Did you completely block the vents or are they venting somewhere else? That crank case has to vent or oil is going to come out somewhere or your going to blow a seal or gasket.
MightyWhitey likes this.
2016 RG Custom Vivid Black
eddienelson is offline
2018 RGS oil leaking out of air cleaner jfitzpatrick500 *General Road Glide Discussions/Pictures 16 08-23-2018 02:56 PM
Pepper-Spraying Texas Cop Update Motorcycle.com *General Road Glide Discussions/Pictures 0 08-24-2016 12:44 PM
Oil misting out my air cleaner....... jjyoung *General Road Glide Discussions/Pictures 7 09-08-2011 11:45 AM
Oil from SE air cleaner? dspencer Road Glide Specific Discussions 10 07-19-2011 01:00 PM
Oil coming out of SE Air Cleaner CSM11 Troubleshooting for Road Glides 10 07-04-2011 08:20 AM
