Idle jumps - Road Glide Forums
 2Likes
  • 1 Post By Dragon Dude
  • 1 Post By ironmark
post #1 of 6 (permalink) Old 12-18-2017, 01:52 PM Thread Starter
Gauncho's Avatar
Idle jumps
Hey everybody, I put a new set of bars on a 15 RGS and at first everything was good and the other day I started it up and the idle was high and it wouldn`t go down so I shut the bike off and looked at the codes and one popped up on the speedo it read -- U0184 -- lost commu W/ Speedo,, Cam Bus... I let it sit over night and started it the next day and it was fine till I took it out for a ride and again the idle while riding was going up and down I have no clue what the problem is anybody out there have any idea before I take it to the dealer.
Gauncho is offline
post #2 of 6 (permalink) Old 12-18-2017, 02:04 PM
Dragon Dude's Avatar
You may have the throttle side control and grip pushed on the the bars to tight. Loosen the screws and back off the bar some to give it a little more play.
Gauncho likes this.
Dragon Dude is offline
post #3 of 6 (permalink) Old 12-19-2017, 07:41 AM Thread Starter
Gauncho's Avatar
Thanks Dragon I`ll do this as soon as I get out there today, hope your right cause with the holiday and all I have nothing to give to the HD dealer. Thanks again.
Gauncho is offline
post #4 of 6 (permalink) Old 12-19-2017, 11:20 AM
Rubimad's Avatar
I dont know what bike you have, but that happened to me once this past summer. I had activated the system to reduce the engine to just one cylinder and only did it when it was very hot. I desactivated it and everything was fine. Activation is easily made by mistake by rolling down the throtle during 3 seconds. For desactivating it is the same way. You can see the status in the info screen.
Rubimad is offline
post #5 of 6 (permalink) Old 12-20-2017, 09:51 AM
If you shut the bike off when the idle is high the ECM will remember the idle speed and the idle speed will be high from then on. To reset the idle speed to normal you need to cycle the ignition on/off 5 or 6 times. If the idle speed fluctuates when the engine is running you may have a vacuum leak and the most common place for a vacuum leak is the vacuum stem on top of the throttle body, there is a rubber cap over that stem and that cap could be missing or cracked which will cause the vacuum leak.
Rubimad likes this.
post #6 of 6 (permalink) Old 12-20-2017, 12:30 PM
Rubimad's Avatar
Really good explanation. I will remember it just in case.
Rubimad is offline
engine stalls and also idle jumps to 2K at times Ahh-Ho RRMC Troubleshooting for Road Glides 12 01-04-2013 01:28 PM
Frog Jumps DemonCity Road Trip Discussions/Stories/Pictures 3 05-15-2011 10:56 PM
Idle vibration / cylinder unloading? hilltoptim *General Road Glide Discussions/Pictures 10 04-25-2011 10:59 AM
'11 CVO Won't Idle Easy Glider Troubleshooting for Road Glides 1 11-27-2010 05:02 PM
Shuts off at idle dgb road Troubleshooting for Road Glides 8 11-06-2010 10:18 AM
