F'ed up my horn - Road Glide Forums
  • 1 Post By Smokey
post #1 of 8 (permalink) Old 12-31-2017, 06:35 PM Thread Starter
NeverEnough's Avatar
F'ed up my horn
Got some chrome switches for xmas and put them on the other day. Went well until i hooked the battery back up. Turned the bike on and the horn was just blasting. Quickly turned it back off. On again, no horn. And now it won't work at all. All of the other switches work properly. Horn switch itself moves as it should, just no sound. Didnt see any blown fuses, and the wiring doesnt look to be broken or pinched. Didnt really mess with the wires during the install anyways. Any ideas? Did i short something? Anybody ever have similar problem? Thanks for any help i can get!
Sent from my SM-G925P using Tapatalk
NeverEnough is offline
post #2 of 8 (permalink) Old 12-31-2017, 09:02 PM
Smokey's Avatar
I think I would start narrowing it down by sticking a needle into each of the two wires coming out of the back of the switch assembly, then touching the two needles together completing the circuit. If the horn blows, then you have a bad switch. If it doesn’t I would next run jumper wires off the battery straight to the horn to make sure it is working. If the horn is working then I would find and test the horn relay switch. I’m guessing the problem is most likely the horn relay but who knows.
Swomack likes this.
Smokey is offline
post #3 of 8 (permalink) Old 01-01-2018, 10:57 AM
Horn I think works by grounding the relay, so a pinched wire anywhere in the switch circuit would have it honking. Check the wire bundle where the switch housing halves clamp together. Possible the relay failed by being stuck on. What year bike?
DuraGlide is offline
post #4 of 8 (permalink) Old 01-01-2018, 12:59 PM Thread Starter
Its a 2013. Seems i'm not terribly electrical savvy. Gonna have a buddy of mine come check it out. Thanks for the input
post #5 of 8 (permalink) Old 01-04-2018, 03:38 PM
i dont have your answer but your name is on the side of my boat
2011 RG ULTRA.
I RIDE. I FISH. HENCE THE THE ROD HOLDERS MOUNTED.
NOTHING LIKE DOING BOTH WHAT I ENJOY IN THE SAME DAY.
CPY84 is offline
post #6 of 8 (permalink) Old 01-04-2018, 04:25 PM
twowheeladdict's Avatar
Pull the Horn fuse and test it. It either blew or the relay failed.
twowheeladdict is offline
post #7 of 8 (permalink) Old 01-04-2018, 04:42 PM Thread Starter
It works now. Weird. The fuse was good. So we checked the wires at the switch and they were fine. Took the horn itself off and checked the wires. Good, but still no horn. Then he fumbled the horn, it bounced off the motor and started blaring. So not sure if something was grounded or not grounded or what. I am sure the spring in the switch was not pushing it all the way back to original position. I don't know, but after a small adjustment to the spring, it is back to normal functioning. Like i said, weird. But thanks for the replies and advice!
post #8 of 8 (permalink) Old 01-04-2018, 09:54 PM
Smokey's Avatar
Glad to hear your issue has been resolved. Electrical malfunctions can sometimes be the most frustrating and hardest to track down.
Smokey is offline
I got FuelMoto(ed) xshovelfreak ECM/Fuel Management systems 10 03-13-2013 08:33 AM
