Loud clunk when starting - 16 RGS - Road Glide Forums
 4Likes
post #1 of 12 (permalink) Old 04-05-2018, 07:34 PM Thread Starter
maverick1five's Avatar
Hey all,
Im looking for some insight on an issue I discovered this evening. Since the weather was pretty nice for once this spring, I was able to go on about a 50 mile ride after work, and upon returning home, I shut the bike off before pulling it into the garage. Once I tried to restart the bike to park it for the night, it turned over for a second and then abruptly made a very loud "CLUNK" sound and stopped turning over. After the "clunk", all of the gauges reset, and "V INERR" flashed for a very brief second. I tried to start the bike again, and the "CLUNK" happened once more. It finally started normally after the third try.
I naturally shut the bike off and tried to start it again, to see if this was a one off thing, and it was not. I tried starting the bike about 6 more times, with the "CLUNK" happening 3 times out of the 6.
Has anyone else had this issue before? Any information is appreciated.
Thanks for your time
maverick1five is offline
post #2 of 12 (permalink) Old 04-05-2018, 08:03 PM
Compensator issue?
Garry1951 likes this.
V-man is offline
post #3 of 12 (permalink) Old 04-05-2018, 08:23 PM
Lord Vader's Avatar
I second the compensator sprocket. It happened to my softail. It sounded awful. I thought something blew up.
JOIN THE DARK SIDE
Lord Vader is online now
post #4 of 12 (permalink) Old 04-06-2018, 12:11 PM
I agree, this sounds like a compensator problem.
post #5 of 12 (permalink) Old 04-06-2018, 12:29 PM
HellInABucket's Avatar
This may sound strange, but check your battery. If its not providing enough cranking amps, this could happen. I would guess even a small amount low could cause it. The chances of this being the problem on your bike is low, but it isnt zero.
flhman, Bruckus and Garry1951 like this.
HellInABucket is offline
post #6 of 12 (permalink) Old 04-06-2018, 12:52 PM
HarleyArcher's Avatar
I agree with the rest. Compensator issue. Mine was replaced around 5k miles. Seems to be a common problem. Hopefully you are still under warranty, if not your looking at about a grand to fix.
Currently bikeless but sticking around for knowledge.
HarleyArcher is offline
post #7 of 12 (permalink) Old 04-07-2018, 08:26 AM
BH#103's Avatar
Don't wait too long on getting it fixed, this same type of issue happened to my Softail. I kept bringing it to the dealer for this issue and I kept getting the usual "they all do that". Then it happened, the starter took a shit and left me stranded at the least convenient time. The dealer picked me and the bike up all the while I got to say "I told you something was wrong". The invoice said the starter was replaced which I do not doubt at all, but I am pretty sure the compensator was done as well. This is going back on my memory a number of years ago, but to answer your question it does not sound normal.
"SLIVER"
BH#103 is offline
post #8 of 12 (permalink) Old 04-07-2018, 09:38 AM
eddienelson's Avatar
Originally Posted by maverick1five View Post
Hey all,
How many miles on the bike
2016 RG Custom Vivid Black
eddienelson is offline
post #9 of 12 (permalink) Old 04-07-2018, 10:23 AM
Little Wing's Avatar
is this a known issue with 16 RGSs?
anybody have a link that discusses this further?
mileage? model/year? other conditions?
Little Wing is offline
post #10 of 12 (permalink) Old 04-07-2018, 10:58 AM
mastergunnera8's Avatar
Its a known issue with all modern twin cams, mileage all over the map...happened to my 2010 with 5600 miles, so far so good on my 16 RGU...
mastergunnera8 is offline
Starting Issue "Clunk" 2016CTRoadGlide Engine Related 3 07-06-2017 07:21 AM
Loud CLUNK sound at shut down Lucky D Engine Related 14 10-05-2014 08:36 PM
Loud clunk RG Rider Troubleshooting for Road Glides 9 06-19-2013 07:49 AM
Clunk Sancho Troubleshooting for Road Glides 27 07-17-2012 07:33 AM
ABS Brakes Loud clunk SCARD1 Troubleshooting for Road Glides 3 09-06-2011 12:05 PM
