High speed handling issue - Road Glide Forums
 42Likes
post #1 of 32 (permalink) Old 04-10-2018, 08:23 PM Thread Starter
eddienelson's Avatar
Ok today me and my son n law went for a ride. Today was just one of those perfect riding days. We ended up being about 120 miles from home and had an hour and half to be somewhere for a family gathering. Long story short we ended up on the Interstate doing about 110ish coming home. I noticed that the bike seemed lite in the front end and was fine during acceleration but when I would let off or hold the throttle the bike would wobble side to side but not bad(almost like the buffeting you get when being behind an 18wheeler). It just didn't feel as planted as it normally does. I never felt uncomfortable with it but it was just different. The front end just doesn't feel as planted as it normally does. I also noticed when I was running about 55mph I needed to slow down just a tad to keep from running into the back of a car. I normally would have tapped the back brake but sometimes Ill just give the front brake a lite squeeze to slow down. This time when I squeezed the front brake I felt a definite shimmy in the front end until I left off of the front brake.
Bike has 20k miles. Just added a Michelin Commander 2 to the rear but didn't replace the factory front Dunlop. Im guessing the front tire might be getting worn. Im also going to jack the front end up and check the head set bearings. I also know that I shouldnt be running 100 plus mph so please dont tell my mom. Could it be a front axle bearing?
2016 RG Custom Vivid Black
eddienelson is offline
post #2 of 32 (permalink) Old 04-10-2018, 08:38 PM
ngshop's Avatar
My guess is the mis-matched (brand) tires.
ngshop is offline
post #3 of 32 (permalink) Old 04-10-2018, 09:21 PM
Lord Vader's Avatar
Could have simply lost a wheel weight going so fast. Maybe One of your tires could be bad and not necessarily the old one. New tire, New problem.
JOIN THE DARK SIDE
Lord Vader is offline
post #4 of 32 (permalink) Old 04-10-2018, 09:37 PM
Nordic Berserker's Avatar
Could be a number of things, definitely check tires etc like Vader above said but the shimmy while squeezing the brake can also be that your rotors are warped. And where the hell are you going at that speed ?
Nordic Berserker is offline
post #5 of 32 (permalink) Old 04-10-2018, 09:56 PM
You'll feel the bumpy out of balance @50-55 and a cup or worn will feel or even hear esp downhill curve, front brakes could be glazed, check for even pad wear(calibers) an vertical push/pull for the bearing, the bearing off times clits though, early warning, hell ck the rotors for gummies too.
I am going with the tire.....but as you know...each step is support by the previous step.
shotgun it
Plus put high speed grease on that axle
madmat and Swomack like this.
reds4 is offline
post #6 of 32 (permalink) Old 04-10-2018, 11:08 PM
BlazingSaddle's Avatar
Only thing that changed was the tire.
Short of having developed a mechanical issue like loose steering head bearing (it’s checked and adjusted as part of the 25k mi service), bearing hub, (doubtful in 20k mi, but if you use a power washer on those wheels...) , axle nut torque, or front end suspension issue (fluid), These are probable but I’m thinking not likely.
That “light” feeling could have even come from the road condition. Don’t imagine you’d go that fast if it was, but did the road look so smooth that it looked “slippery”? A slippery road would make the front end feel light at that speed (as would a worn front tire).
The shimmy when applying the front brake, did you feel a pulse in the brake lever, or are you saying the front end shimmied side to side, but the braking felt smooth? If the latter, you’ve got slop somewhere which might also cause that light feeling, but if you felt it in the lever, probably a warped rotor, or as Reds4 states glazed.. If it’s a rotor (warped or glazed) you would always feel it in the lever when applying the brake regardless the speed you’re going, it’s just more pronounced at higher speeds.
My guess is 1. worn front tire, 2. mismatched (with worn front) tires, and 3. warped rotor.
BlazingSaddle is offline
post #7 of 32 (permalink) Old 04-11-2018, 05:58 AM Thread Starter
Thanks for the input. If I can get home at a reasonable time tonight I’ll put the bike on the stand and check the front end. Come to think of it what reds4 said about the rotors makes sense. I have noticed when stopping the front brake wasn’t as smooth as it normally is.
post #8 of 32 (permalink) Old 04-11-2018, 06:12 AM
Got a solution for you my friend...No buffeting, no high speed wobble, smooth brakes...
madmat, reds4, Swomack and 5 others like this.
Singlebeam is offline
post #9 of 32 (permalink) Old 04-11-2018, 06:38 AM
RGKen's Avatar
Could be as simple as wrong tire pressure. Even the wrong tire pressure in the rear can make it feel like the front is the issue at high speed.
2018 FLTRXS
RGKen is offline
post #10 of 32 (permalink) Old 04-11-2018, 06:39 AM Thread Starter
Bullshit! I guantee I can tear it up...lol
Singlebeam likes this.
2018 handling issue help needed porschemann Troubleshooting for Road Glides 7 07-30-2018 10:19 PM
5 speed or 6 speed?? Pooh63 *General Road Glide Discussions/Pictures 8 06-22-2017 01:20 PM
Ape's and handling the bike at speed? gbourdon Controls & Handlebars 15 01-11-2012 06:24 AM
High Speed Sweeper Wobble? FLTRI *General Road Glide Discussions/Pictures 5 09-17-2010 11:39 AM
High Speed wobble on rear end Hub *General Road Glide Discussions/Pictures 0 06-28-2010 07:28 PM
