Stripped nut insert, inner faring. - Road Glide Forums
 10Likes
post #1 of 21 (permalink) Old 05-16-2018, 02:13 PM Thread Starter
BeechRG's Avatar
While putting my faring back on I cross threaded a nut insert located on the left side of the bike. It is the screw that holds the small wind deflector on and also Connects to the faring itself. I went to HD today and they said they dont have this part alone and you have to buy the entire assembly.
Does anyone know where to find this or if it is a HD part, have a part number ?
BeechRG is offline
post #2 of 21 (permalink) Old 05-16-2018, 02:35 PM
Swomack's Avatar
Originally Posted by BeechRG View Post
While putting my faring back on I cross threaded a nut insert located on the left side of the bike. It is the screw that holds the small wind deflector on and also Connects to the faring itself. I went to HD today and they said they don’t have this part alone and you have to buy the entire assembly.
Attachment 364073
Try McMaster-Carr Or Grainger
You should be able to find a replacement or come up with another fix.
Here's a link to "NUT INSETS"
https://www.mcmaster.com/#nut-inserts/=1cvbqfx
https://www.grainger.com/product/32F...180516193700:s
Swomack
Jacksprat56 likes this.
My Gallery / Click Below Link
Swomack is offline
post #3 of 21 (permalink) Old 05-16-2018, 05:29 PM
norm9278's Avatar
I haven't torn one up that bad, but there's supposed to be rubber around that!
You can get them at Ace Hardware. Called wellnuts.
norm9278 is offline
post #4 of 21 (permalink) Old 05-16-2018, 05:39 PM
RGKen's Avatar
That is not a "wellnut" like the 2013 & older glides use for the windshield. That is molded into plastic in the inner fairing to mount the outer fairing.
2018 FLTRXS
RGKen is offline
post #5 of 21 (permalink) Old 05-16-2018, 06:45 PM
bucketlisthd's Avatar
I stupidly buggered one of those. I ran a tap though it and fixed it. A tap & die set isn't too expensive and is handy to have around
'15 Roadglide Special
'87 FXR 100"
'79 Goldwing cafe
bucketlisthd is offline
post #6 of 21 (permalink) Old 05-16-2018, 10:00 PM
Little Wing's Avatar
Attachment 364073
sorry can't help with a part number. can it be anchored back in the fairing?
could you post a pic of where it goes?
how did you get the windshield off?
Little Wing is offline
post #7 of 21 (permalink) Old 05-16-2018, 10:25 PM
UT_Larry's Avatar
Use vice grips to separate. Tap & die the threads. JB weld the nut insert into fairing then hammer a brad or fine wire to make the fit more secure. I used that technique on my 96 EGU, no problems for I’ve 3 years with that repair.
ironmark and Jacksprat56 like this.
UT_Larry is offline
post #8 of 21 (permalink) Old 05-17-2018, 07:51 AM
Swomack's Avatar
BINGO
JB WELD WILL WORK PERFECTLY FOR THIS FIX
Swomack
Swomack is offline
post #9 of 21 (permalink) Old 05-17-2018, 08:13 AM
Skickat frn min iPhone med Tapatalk
ultra98 is offline
post #10 of 21 (permalink) Old 05-17-2018, 02:25 PM
geo8866's Avatar
I stripped a similar one. Went to the dealer, pointed at the part on a bike on the floor, and the guy got it in a minute. $3 if I remember.
geo8866 is offline
Stripped Inner Fairing Screw Hole the88virgnian Do-IT-Yourself 8 08-25-2016 08:44 AM
Major Sound upgrade w/ 6x9 inner faring JonnyU Audio 33 01-26-2014 09:13 PM
Wtb inner faring and gauge pod faring vegasxt Wanted! (Buy or Trade) 2 03-29-2013 08:35 PM
Painted my inner faring Hotroadking Do-IT-Yourself 12 02-10-2011 11:55 AM
Soft Dash Inner Faring for Road Glide BDMastiff *General Road Glide Discussions/Pictures 7 09-08-2010 02:40 PM
