Shifter arm/rod issue - Road Glide Forums
 11Likes
post #1 of 17 (permalink) Old 07-23-2018, 02:01 PM Thread Starter
Ibdman21's Avatar
I have an issue with my shifter arm slipping off of the rod. I've tightened the screw down as far as I can and it still seems to slide to the end of the rod, barely holding onto the splines. Any advice will be greatly appreciated.
Ibdman21 is offline
post #2 of 17 (permalink) Old 07-23-2018, 02:24 PM
calgaryglide's Avatar
Hello Newb,
Need a little more information from you.
What year is your bike and how many miles on it?
So is it the end of the shaft that goes thru the primary and is just below the horn? Depending on the mileage on your bike, your shifting style, you have probably worn both the male and female splines in the connection, especially if the connector seems to keep sliding on the shaft.
The shaft is inexpensive and easy to fix. For a temporary cure until your parts arrive you can zip tie from the front shifter over the top of the primary to the vertical connector that the bolt goes thru. This is a temporary measure to keep you travelling or riding until replacement parts are installed.
When you get the chance to replace the shift shaft I suggest viewing this video linked here for how to do it. Go to the 4:00 mark of the video.
https://www.youtube.com/watch?v=5XKOXTvE2hA
Calgaryglide
Ibdman21 likes this.
calgaryglide is offline
post #3 of 17 (permalink) Old 07-23-2018, 02:44 PM Thread Starter
Ibdman21's Avatar
15 RGS with 16k miles. I've replaced the arm and shaft once at about 11k. Someone told me it was due to me heal shifting. After I've replaced them, it still slides, but not completely off the shaft.
Ibdman21 is offline
post #4 of 17 (permalink) Old 07-23-2018, 03:37 PM
08Zinc's Avatar
Common issue. I'm about due to have it happen again. If under warranty, it is a quick fix at the dealer. If not, follow calgaryglide's info as it is spot on.
Blessings, Zinc -
08Zinc is offline
post #5 of 17 (permalink) Old 07-23-2018, 03:46 PM
Swomack's Avatar
The shifting setups on these bikes sucks
I've had to replace mine twice but the last time seems like everything is A OK so far
A simple fix never the less
Swomack
My Gallery / Click Below Link
Swomack is offline
post #6 of 17 (permalink) Old 07-23-2018, 04:40 PM
madmat's Avatar
When I took my heal kicker off, my problem went away.
18 RGS Bonneville Salt Pearl
madmat is online now
post #7 of 17 (permalink) Old 07-23-2018, 05:14 PM
ChromeSpark's Avatar
Mines been off after getting home the first time and I've had no issues. Heel shifters on anything I've been around seem to develop issues faster than toe only.
madmat and eddienelson like this.
"It's a motorcycle, itīs not supposed to be comfortable, quiet or safe. The wind noise is supposed to hurt your ears, the seat should be hard and riding it should make you s**t your pants every now and then."
ChromeSpark is offline
post #8 of 17 (permalink) Old 07-23-2018, 07:41 PM
Bruce00's Avatar
Everybody I know that has had issues, has a heel shifter on their bike.
If you want to eliminate any problems going forward, replace with AFTERMARKET parts, it seems Harleys lowest bidder has some soft metal.
btw.....Never had an issue with mine in 45K miles, but I removed the heel shifter as soon as the bike got home and I replaced the linkage with non Harley parts. To be honest, I replaced the linkage because I found some contrast cut parts I liked, after I replaced the parts I found out about the issues and cause
Doug06rg likes this.
2015 RoadGlide Special
Tuned by Jamie @ Fuel Moto w/Rinehart 2>1
Bruce00 is offline
post #9 of 17 (permalink) Old 07-23-2018, 08:24 PM
FDR's RGC's Avatar
Replace the pinch bolt with a grade 8 hex head. You can crank it down without breaking the bolt. 98k on mine without problems. I just check it when I change my oil.
FDR's RGC is offline
post #10 of 17 (permalink) Old 07-24-2018, 04:57 AM Thread Starter
Ibdman21's Avatar
Thank you everyone for your advice. I think I'll give the non-HD parts a try. Also thinking about removing the heel shifter too so I won't be tempted to use it ever again.
Ibdman21 is offline
Shifter arm loose but functioning laxinharley Troubleshooting for Road Glides 16 11-12-2015 04:39 PM
Stripped out shifter rod! Neil V. Engine Related 23 04-14-2014 02:09 AM
Shifter Arm Flew Off firehouse18 Troubleshooting for Road Glides 14 01-21-2013 10:59 AM
Battistinis FloorBoards-Heel&Toe Shifter-Brake Arm Sikk1 Equipment-RG 6 09-10-2012 10:29 AM
Shifter Rod Change dklanecky Aftermarket Accessories 8 10-23-2010 09:33 AM
