Possible electrical problems - Road Glide Forums
 3Likes
  • 2 Post By DoubleJ
  • 1 Post By RGKen
post #1 of 4 (permalink) Old 07-23-2018, 04:19 PM Thread Starter
2015 road glide special. Had stereo upgrade a month ago. 3 times since then brakes won't release while coming to a stop. One time it has applied them buy its self. Did not touch pedal or lever. After a few minutes they release and I go on.
Wondering if the charging system is not enough to carry the upgrade and possibly causing abs to freak out. Bike has 9k on it and has been a dream. Now a nightmare.
Help!!!!🤔
MattLaura is offline
post #2 of 4 (permalink) Old 07-23-2018, 04:38 PM
DoubleJ's Avatar
I'm not sure a radio upgrade would affect the braking system like that. I would however HAUL your bike, not ride it to the nearest dealer/shop to have that looked at. Could be something seriously wrong with your ABS module.
Doug06rg and ChromeSpark like this.
2017 Road Glide Ultra
DoubleJ is offline
post #3 of 4 (permalink) Old 07-23-2018, 06:19 PM
RGKen's Avatar
Could be your brake pistons needs to be cleaned. If too much brake dust and grime build up on the sides they will stick and not retract all the way. You could take your brake calipers loose and remove the brake pads. Take an old thin set of brake pads and just stick in there and pump the brake lever to push the pistons out against the old set of pads. Then take some brake clean and a stiff plastic bristle brush and clean the pistons. Just don't get too vigorous around the rubber seals around the pistons. When cleaned and still using the old pads, spread them apart and press the pistons back into the calipers. Install the good brake pads and re-install the brake calipers. Pump the brakes to build the pressure back up and then test them. That should do the trick but if it doesn't then you could have some contaminated fluid in there causing the issue. Then you will need to take to a dealer or indy to get the brakes flushed and evaluated.
Have you had the brakes flushed since you've owned the bike? How old is the fluid that is in there.
Bruce00 likes this.
2018 FLTRXS
RGKen is offline
post #4 of 4 (permalink) Old 07-24-2018, 09:41 AM
Dice21's Avatar
Sounds a lot like an ABS issue. I hate taking stuff to the dealer, but that's exactly what I'd do.
I had a similar issue when I swapped a front wheel. Front ABS sensor was damaged.
11" Road6 bars. Hell's Foundry hidden fairing supports. Bad Dad bags. S&S air Stealth air cleaner. FP3. Custom Dynamics lights. Memphis Shades windshield. Decatted head pipe. Tab Slipons w/Zombie baffles. B52 w/ ARC 602's
Dice21 is offline
Is It Possible to Exceed Electrical Capacity of 17 RGU with After-market Accessories Harley Rider *General Road Glide Discussions/Pictures 4 08-12-2017 02:07 PM
Electrical possible sensor issue...??? Johnzz1420 *General Road Glide Discussions/Pictures 5 08-05-2013 04:31 PM
Possible Electrical Charging issues??? paco ritter Troubleshooting for Road Glides 5 10-05-2012 09:26 PM
2012 fltru electrical problems Top_P Troubleshooting for Road Glides 6 04-17-2012 09:53 AM
Road 6 Custom apes & possible brake problems cwdouble Controls & Handlebars 6 02-16-2012 07:34 PM
