Vibration - Road Glide Forums
 2Likes
  • 2 Post By antifrez72
post #1 of 10 (permalink) Old 07-28-2018, 10:54 AM Thread Starter
antifrez72's Avatar
Vibration
2009 recently changed inner primary bearing, clutch hub, clutches, baker chain adjuster, due to the primary chain being to tight.
Seems to have cured most of he problems now its very noticeable when under load that there is a bad coming from rear wheel or tranny? Seems to be even worse when on rough road?
I know i need some new shocks and there coming this week but any ideals on this ?????
Tranny bearings?
antifrez72 is offline
post #2 of 10 (permalink) Old 07-28-2018, 10:58 AM
Mike U's Avatar
Have you changed any of the rear wheel bearings?
There's also a bearing in the Rear Belt Sprocket as well as a Rubber Cush Drive Mount.
Mike U.
USMC 1975-1977
Semper Fi!
Nothing else matters!
Mike U is offline
post #3 of 10 (permalink) Old 07-28-2018, 01:09 PM Thread Starter
antifrez72's Avatar
Have not but pulling rear wheel now
post #4 of 10 (permalink) Old 07-28-2018, 01:22 PM
Mike U's Avatar
Best of luck!
Mike U.
USMC 1975-1977
Semper Fi!
Mike U is offline
post #5 of 10 (permalink) Old 07-28-2018, 02:43 PM Thread Starter
antifrez72's Avatar
So got the wheel off none of the bearings feel loose but a couple feel
Awful tight. Im going to change them reguardless aincebits off add the new shocks and go from there.
I dont like the process of elimination because it cost....
anymore ideals ?????
post #6 of 10 (permalink) Old 07-28-2018, 04:06 PM
RGKen's Avatar
do you know for a fact that the rear wheel is balanced properly? Since you have it off it would be real easy to have it checked.
2018 FLTRXS
RGKen is online now
post #7 of 10 (permalink) Old 07-28-2018, 05:19 PM Thread Starter
antifrez72's Avatar
It only has the vibration underload on the throttle when coasting its smooth
post #8 of 10 (permalink) Old 07-29-2018, 10:16 AM
Don't forget to check the rear pulley bearing.
post #9 of 10 (permalink) Old 08-03-2018, 01:21 PM Thread Starter
antifrez72's Avatar
Ok changed the rear wheel bearings and now shes smooth as silk. Thanks
This was after changing the busted clutch hub and inner primary bearing and race
Mike U and MotorcycleGoat like this.
post #10 of 10 (permalink) Old 08-03-2018, 01:58 PM
RGKen's Avatar
Good to hear and glad you figured it out. Just an FYI, there are 2 bearings in the rear pully and if your ever need to change those you will need a press to get them out and the new ones in. It's the easiest way for me at least.
2018 FLTRXS
RGKen is online now
Windshield vibration acexp02 Troubleshooting for Road Glides 8 06-02-2011 01:54 AM
bad vibration on the decel!!! Help!!! shimo Troubleshooting for Road Glides 12 05-31-2011 05:29 PM
Bag vibration NakedSnowman Troubleshooting for Road Glides 3 05-09-2011 12:53 PM
Idle vibration / cylinder unloading? hilltoptim *General Road Glide Discussions/Pictures 10 04-25-2011 10:59 AM
Floorboard Vibration jcanrun *General Road Glide Discussions/Pictures 4 03-14-2011 02:04 PM
