Is there a test to prove the compensator bad ? - Road Glide Forums
post #1 of 12 (permalink) Old 08-20-2018, 05:53 PM Thread Starter
I have an 08 with a 96" motor . going to start it I will get an intermittent gnashing sound . I am assuming it is the compensator but seeing as these are not free, I'd like to test it before dropping coin on it and having it be something else like the starter clutch. Thanks in advance , M
MarkL is offline
post #2 of 12 (permalink) Old 08-20-2018, 06:17 PM
RFG7680's Avatar
If you have an intermittent knock in your primary. It's bad. There is no testing it. Only replacing it. My 08 had it when I rode it out of the showroom with 6 miles on it. They were pretty much junk from day 1. So mileage means nothing on the older bikes. Are you the original owner? If not it's likely been changed already. Switch to the direct drive sprocket. I am. My 16 with 20k is starting to knock. I wont be putting anything but the direct drive sprocket in.
RFG7680 is offline
post #3 of 12 (permalink) Old 08-20-2018, 06:19 PM
Go to you tube and look up Harley compensator. Look for the one that says “clunkity klunk” and see if the noise is similar. It has an illustration of the guts too, which helps to make sense of the noise. I think the only real test is someone knowledgeable looking (tearing) in to it. Good luck!
2016 Road Glide Ultra
dreeves is offline
post #4 of 12 (permalink) Old 08-20-2018, 08:02 PM Thread Starter
Looks like I will be knowledgeable when I'm done LOL . Thanks
MarkL is offline
post #5 of 12 (permalink) Old 08-20-2018, 09:48 PM
[QUOTE=MarkL;4529891 . going to start it I will get an intermittent gnashing sound ./QUOTE]
Are you in gear
reds4 is offline
post #6 of 12 (permalink) Old 08-21-2018, 05:50 AM Thread Starter
[quote=reds4;4529941]
Originally Posted by MarkL;4529891 . going to start it I will get an intermittent gnashing sound ./QUOTE
Are you in gear
No , out of habit I put it in neutral before starting.
MarkL is offline
post #7 of 12 (permalink) Old 08-21-2018, 05:56 AM Thread Starter
After watching several video's . I see that a bad compensator will move left and right by hand . A compensator in good health will not do this while installed on the bike .
MarkL is offline
post #8 of 12 (permalink) Old 10-13-2018, 06:41 PM Thread Starter
So . After I installed my new compensator ,There is no more gnashing when I start it hot or cold. No more clunk when I shut it off and it seems crisper running , it could be my imagination . Thanks for the help . M
MarkL is offline
post #9 of 12 (permalink) Old 10-13-2018, 08:26 PM
James's Avatar
What compensator did you install?
James is online now
post #10 of 12 (permalink) Old 10-14-2018, 06:33 PM Thread Starter
https://www.harley-davidson.com/stor...-GM+PDP+Bottom
James likes this.
MarkL is offline
Going to test ride a 2018 Roda Glide what should I test. Daicaothu *General Road Glide Discussions/Pictures 55 08-16-2018 05:20 PM
New Compensator or Compensator eliminator mrmoto95 Engine Related 11 03-28-2018 07:10 PM
bad VR or bad stator? Gonekat Troubleshooting for Road Glides 14 11-05-2014 05:29 PM
Install was not that bad..Alpine and J&M not a bad team Sixnine68 Audio 10 01-31-2014 04:28 PM
UGLIER than SIN!!! Photos to Prove it! Torquey Windshields 112 08-18-2013 07:37 AM
