Red key light - Road Glide Forums
 6Likes
  • 2 Post By duglauraflht
  • 3 Post By Thermodyne
  • 1 Post By Phantom6722
post #1 of 8 (permalink) Old 08-30-2018, 09:38 PM Thread Starter
chowman63's Avatar
Red key light
Hello all. Hope someone can chime in and give there thoughts.
Went for a ride today and about 50 miles in the red key light comes on. Stopped and checked on things,shut the bike down. Started back up and continued on my way, all good, light off. 20 miles down the road red key light back on. This time no right blinker. Stop and get gas, and all is working again. Decided to head back towards home and the left blinker stopped working, red key light back on. I do have all custom dynamics led lights. Had them for 3 or 4 years. Bike is a 2011. Iím thinking it could be a bad load equalizer. I havenít checked the codes yet. Thoughts anyone. Thanks
chowman63 is online now
post #2 of 8 (permalink) Old 08-30-2018, 10:05 PM
FDR's RGC's Avatar
Check for codes. A stored code will cause red key light. Load equalizer could cause light.
FDR's RGC is offline
post #3 of 8 (permalink) Old 08-31-2018, 12:20 PM
duglauraflht's Avatar
Exactly what happened to my much older glider, I have Custom dynamics front and rears, even tail light....My load equalizer rubbed through one wire and thru the red key light....Bike ride fine back home til I removed and found the pinched wire....Replaced and all good.....Good luck.
madmat and geo8866 like this.
duglauraflht is offline
post #4 of 8 (permalink) Old 08-31-2018, 12:26 PM
Thermodyne's Avatar
First thing to do is change the battery in the fob. A weak fob signal can be blanketed out by stronger signals and turn the security light on.
madmat, geo8866 and duglauraflht like this.
Thermodyne is offline
post #5 of 8 (permalink) Old 08-31-2018, 05:52 PM Thread Starter
chowman63's Avatar
Thanks guys. I did check the codes this morning, B1121,1122,1123,1124 also B1006, 1007. Checked battery connection was fine. Pulled all the LEDs and put a little dielectric on. Checked all the wire leading to and from turn signals all looked fine. Last thing I did was replace the load equalizer. I will run and get new fob battery in the morning. Going to go for a ride tomorrow and see how things work. Iíll keep you posted. Thanks again guys.
post #6 of 8 (permalink) Old 09-01-2018, 04:27 PM
Phantom6722's Avatar
A bad load equaliser usually gives a fast flashing on the LED indicators.
geo8866 likes this.
Cheers Skip
Phantom6722 is offline
post #7 of 8 (permalink) Old 09-01-2018, 11:05 PM Thread Starter
chowman63's Avatar
Ok, so I cleared all the codes after installing the new load equalizer. B1006 andB1007 stilled stayed after running the bike. I checked the battery, 12.5 volts. Started the bike it didnít drop at all. Checked at 2000 rpms 14.30 volts. Cleared codes again and went for a ride. Maybe 20 miles, all seemed fine, no red key light. I donít know. Will go riding again in a day or so.
post #8 of 8 (permalink) Old 09-08-2018, 10:28 PM Thread Starter
chowman63's Avatar
Ok,So just a update on the red key light. Went for a ride, Friday,Saturday 400 miles. Bike ran perfect. So as I said in my earlier post. The only thing I did was replace the load equalizer. Problem solved. Thanks all
red key light hazguy *General Road Glide Discussions/Pictures 5 05-23-2014 03:43 PM
Red key light stays on jprider4life Engine Related 10 04-27-2014 09:40 PM
Red Key Light on Odometer. Q-Hog Troubleshooting for Road Glides 25 12-30-2012 02:28 PM
Red Key Light in Speedo Bar Regular *General Road Glide Discussions/Pictures 5 05-25-2012 10:02 AM
Red key light stays on choppermike Troubleshooting for Road Glides 7 03-02-2012 08:29 AM
