starting question - Road Glide Forums
 2Likes
  • 1 Post By vivid black
  • 1 Post By 08Zinc
post #1 of 5 (permalink) Old 09-03-2018, 02:22 PM Thread Starter
starting question
I have 2017 Road Glide Ultra. 7,700. miles on it. Sometimes when I pull in clutch in gear to start it nothing happens on. I put it in neutral and it starts right up. Has anyone have that happen.
ksbutler44 likes this.
vivid black is offline
post #2 of 5 (permalink) Old 09-03-2018, 02:32 PM
08Zinc's Avatar
Yep. Multiple threads on this. Take it to the dealer and have it repaired under warranty. Could be either of 2 parts that failed.
Jacksprat56 likes this.
Blessings, Zinc -
08Zinc is offline
post #3 of 5 (permalink) Old 09-03-2018, 02:45 PM
try to clean the neutral switch contacts, the switch is located forward of the gearbox refill cap and the two wires are "spark plug style", so they are easy to be removed for cleaning.
Beaver is offline
post #4 of 5 (permalink) Old 09-03-2018, 07:20 PM
Typically when this is a customer complaint, the solution is to replace the LHCM (left hand control module). The clutch switch has failed and it’s not seeing the fact that you have the clutch lever pulled in. If you are out of warranty, you can buy the P&A lighted switches (the pair) for about what just the LHCM will cost you.
2018 FLTRXS Wicked Red
Harley Master Tech
crazy4ink is offline
post #5 of 5 (permalink) Old 09-03-2018, 08:47 PM
I have a 2017 RGS and I had that issue. I took it in and they replaced the left hand switch housing.
Sent from my SM-G955U using Tapatalk
ksbutler44 is online now
Starting RU buy process today b104396 Road Glide Specific Discussions 21 05-26-2011 08:28 AM
starting to scan some road trip pics JacktheBagger Road Trip Discussions/Stories/Pictures 6 05-13-2011 08:10 PM
Everything is starting to come together. allofus81 *General Road Glide Discussions/Pictures 2 04-03-2011 08:40 PM
Starting of the transformation... GLYDDN11 *General Road Glide Discussions/Pictures 27 03-01-2011 04:34 PM
Starting failure jramy Troubleshooting for Road Glides 6 02-11-2011 03:11 PM
