2016 road glide won’t start in gear - Road Glide Forums
 13Likes
post #1 of 23 (permalink) Old 09-05-2018, 12:13 AM Thread Starter
Vsarman33's Avatar
Just realized a few days ago my 16 road glide special will not start when in gear and clutch lever pulled in, it used to before, anyone else have that happen to them?
Vsarman33 is offline
post #2 of 23 (permalink) Old 09-05-2018, 12:21 AM
texasnurse's Avatar
Have you replaced grips recently?
Check that the end cap on the clutch switch is intact
texasnurse is offline
post #3 of 23 (permalink) Old 09-05-2018, 12:36 AM Thread Starter
Vsarman33's Avatar
No, still running stock grips
post #4 of 23 (permalink) Old 09-05-2018, 06:55 AM
FDR's RGC's Avatar
Check your clutch safety switch at lever. Might have to loosen and move it slightly then retighten.
Stoic Joker likes this.
FDR's RGC is offline
post #5 of 23 (permalink) Old 09-05-2018, 06:57 AM
OldNerdGuy's Avatar
Odds are something disturbed the clutch switch in the handlebars. Or, the switch broke. That is a CAN Bus switch pack, and the switch is supposed to be out with the clutch lever pulled in. Not sure how you can test that on the clutch side, as it probably is starting fine in neutral, and you cannot engage the clutch with the lever off. You can check the travel on the button. Harley shops probably have that built into some computerized test.
OldNerdGuy is offline
post #6 of 23 (permalink) Old 09-05-2018, 07:00 AM
Common issue. As mentioned, make sure everything is tight and that your clutch lever is hitting the clutch switch. If you haven’t changed grips or bars, then that’s pretty not needed. More than likely, your LHCM has a problem. Since they are non-repairable (like the older models), you will Ned the whole switch pack. If you’re out of warranty, you can buy the P&A lighted switches (the pair) for what just the LHCM would cost you.
08Zinc, Bruce00 and RGKen like this.
2018 FLTRXS Wicked Red
Harley Master Tech
crazy4ink is offline
post #7 of 23 (permalink) Old 09-05-2018, 07:22 AM
RGKen's Avatar
It's not a good practice to do that anyway. It is always best to start in neutral as there is still a small amount of drag at startup when it's in gear even with the clutch pulled in. You can tell this by the bike lurching forward at startup.
Here is a copy and paste explanation from another forum:
[I]"Here's why:
In neutral, you're (starter) spinning the clutch basket and trans output shaft, in the 24 onces of trans fluid, with gears unmeshed at idle.
With clutch in/in gear, you're spinning the clutch basket, with the clutch plates separated, in 32-38 onces of primary oil. There's parasitic drag between the wet clutch plates that doesn't break when cold, or the first time you pull the clutch lever.
Both can depend on fluid viscosity (20w50 vs 75w140 for trans), ambient temps, and/or bike's operating temp.
If the bike is WARM, either/or is about the same. Oil is more fluid and clutch plates separate easier, with less drag.
IF COLD, the clutch plates can stick, causing higher drag, wearing on the starter jackshaft and primary bughing, due to higher amps to start the bike.
TEST: First thing in the morning, put your bike in gear (not running) and pull clutch and try to push it. You'll immediately note the excess drag due to the clutch plates sticking...."
I'm still researching for an answer to your symptom as this seems to pop up fairly frequently. If your clutch switch is good then there is possibly a fuse that is blown or a pinched wire somewhere. Someone stated that if they pull the clutch lever in 3-4 times rapidly then it would work. You could see if that works for you but if not just keep starting it in neutral and ride on until you find the fix. Better for the bike anyway but you still need to find the answer to why it will not start in gear.
Bruce00, Swomack and Jacksprat56 like this.
2018 FLTRXS
RGKen is online now
post #8 of 23 (permalink) Old 09-05-2018, 08:06 AM
skratch's Avatar
while true, there are times that you might want to be able to just pull in the clutch to start. like if your bike stalls in the middle of an intersection......
Mike U, snarley53 and crazy4ink like this.
skratch is offline
post #9 of 23 (permalink) Old 09-05-2018, 09:13 AM
RGKen's Avatar
Not disputing that and that is why I said I would still try and help find the answer to his question. It should do it so something is wrong and needs to be rectified.
2018 FLTRXS
RGKen is online now
post #10 of 23 (permalink) Old 09-05-2018, 09:45 AM
texasnurse's Avatar
One of the reasons I passed on a used ‘17 roadglide...
Tags
clutch , start
Damn--Won't start after bar swap. RedDogNC Controls & Handlebars 26 09-15-2016 09:35 PM
Why won't the glide start 13HDGLIDE Troubleshooting for Road Glides 19 07-24-2014 01:31 PM
2010 Road Glide won't start kildar Troubleshooting for Road Glides 5 04-14-2012 02:39 PM
2001rg won't start PRDIAZ1 Troubleshooting for Road Glides 6 04-03-2011 10:06 AM
bike won't start briscoe *General Road Glide Discussions/Pictures 11 11-28-2010 10:25 AM
