Fuel Gauge Twilight Zone ? - Road Glide Forums
post #1 of 8 (permalink) Old 09-27-2018, 08:08 PM Thread Starter
I have an 07 Glide with new gauges that all work correctly. The fuel shows low to full correctly. My issue is that the Lo Fuel Yellow light appears when i am full of gas. It goes out after about 1/3 is used. I just wondered if anyone has an idea. I do not see any wiring issues. I hope I'm not in fuel gauge Twilight Zone ! Any help would be appreciated ! Ty, Dwight Stark / Arkie
Arkie is offline
post #2 of 8 (permalink) Old 09-27-2018, 08:17 PM
You still having issues?
Jeff6146 is offline
post #3 of 8 (permalink) Old 09-28-2018, 07:52 AM Thread Starter
Yes I am. According to factory manual all voltage readings are correct at pickup connection to main harness in front of the seat. It is what ever triggers the indicator light on the speed that I'm confused about.
Thanks,Dwight Stark
Arkie is offline
post #4 of 8 (permalink) Old 09-28-2018, 10:55 AM
ChromeSpark's Avatar
Not sure on HDs but other rides I've had the low fuel light issue and found it is triggered off a seperate sensor, ie. not fuel level system. The diagnostics should be in the electrical manual, I don't have one (need to fix that) On the one with a problem, I soaked it in carb cleaner and it started working. I don't know if that is applicable in this case.
"It's a motorcycle, itīs not supposed to be comfortable, quiet or safe. The wind noise is supposed to hurt your ears, the seat should be hard and riding it should make you s**t your pants every now and then."
ChromeSpark is offline
post #5 of 8 (permalink) Old 09-28-2018, 12:50 PM
Thermodyne's Avatar
See if it has a historic B1004 or B1005 trouble code stored. Any time the voltage on the Y/W wire at the speedo is high or low from the spec range it will set a code and turn the low fuel lamp on.
Thermodyne is offline
post #6 of 8 (permalink) Old 09-28-2018, 07:40 PM Thread Starter
Thank you Thermodyne, you are correct. I do have the B1004 code. I have not had time to check voltage and ground to speedo plug. That is on my Saturday agenda. Thank you now I have a direction.
Much appreciated,Dwight Stark / Arkie
Arkie is offline
post #7 of 8 (permalink) Old 12-27-2018, 07:16 AM
What bike is it
Jeff6146 is offline
post #8 of 8 (permalink) Old 12-27-2018, 10:11 AM
Thermodyne's Avatar
On a 2011, the y/w wire is the circuit to the gauge, it also runs to the speedo head. The speedo head looks for a specific resistance to ground, something greater than 170 ohms. So it then uses that to estimate that there is 1 gallon of fuel left and turns the lamp on.
I don't have a diagnostic manual on a 07, but I suspect it uses the same parameters, since they usually go with whatever Delphi suggests.
HARLEY DAVIDSON 2012 ROAD GLIDE CVO Candy Cobalt and Twilight Blue CVOGlide Bikes for Sale 6 01-28-2018 01:04 PM
Fuel gauge, air temp gauge inop Crcarnage87 Troubleshooting for Road Glides 1 04-17-2017 06:19 PM
Chopped CVO Cbaolt Blie/Twilight Tour Pak Cory Parts for Sale 8 02-23-2015 04:56 PM
Twilight Blue 93-331-29psi Paint & Bodywork Section 9 08-29-2014 10:05 AM
