dtc code b134200 Help me what is it? - Road Glide Forums
post #1 of 5 (permalink) Old 11-23-2018, 09:46 PM Thread Starter
I could use some help finding what this code is b134200?
I can't find anything on it.
Someone please help me out.
LaCcTv_com is offline
post #2 of 5 (permalink) Old 11-23-2018, 09:57 PM
WA Bull's Avatar
Info I have says B codes are set by Radio, Instruments and BCM. Closest match I can find is B1342 Rear left speaker open. Do you have rear speakers set up? If so, there might be a loose wire connection, either at the speaker or at the head unit.
WA Bull is offline
post #3 of 5 (permalink) Old 11-23-2018, 09:58 PM Thread Starter
i have the left rear speaker out.
would that cause the check engine light to come on?
post #4 of 5 (permalink) Old 11-23-2018, 10:29 PM
Sometimes it would be nice if you provided a little more info like the year of the bike and mods that you had done to the bike. B codes are related to the audio system and since the left rear speaker is out it would be a good place to start.
post #5 of 5 (permalink) Old 11-24-2018, 08:49 PM
WA Bull's Avatar
Assuming you have a 2015 or newer RG, CANBUS diagnostics are very sophisticated. The computer literally knows all. It monitors every light bulb, every sensor, practically everything. You answered your own question - you took the speaker out and must have turned the ignition switch on, the system detected a problem and alerted you to it.
WA Bull is offline
04-07 DTC Codes ironmark Troubleshooting for Road Glides 5 08-31-2015 11:31 PM
Error code question or at least I think it's an error code wvdave Troubleshooting for Road Glides 1 07-15-2015 10:21 AM
DTC code question Mason417 Troubleshooting for Road Glides 3 09-03-2013 04:41 AM
Dtc code question DEMONDGE Troubleshooting for Road Glides 11 07-31-2013 10:03 AM
dtc code incorrect skipperfltr Troubleshooting for Road Glides 8 06-24-2011 05:50 PM
