Rear Belt Cam Adjuster - Right side moving - Road Glide Forums
post #1 of 12 (permalink) Old 12-17-2010, 08:47 PM Thread Starter
I adjusted my rear belt tension the other day. What's happening is that when I torque down the right cone nut (axle nut), that cam adjuster on the right rotates leaving about a 1 mm space between the cam and the tab on the swingarm. The cams on both sides are suppose to sit flush on those little tabs on the swingarm. But, for the life of me, I can never get the right one to keep in contact with the tab. I've even pulled out the axle a little bit and took off and examined the cam to see if there is a manufacturing imperfection, but none is present. I use a wrench on the left side to keep the cam adjuster/belt tension in place while I tighten down the right side axle nut. The wheel still appears lined up correctly it's just that the cam (or big washer) won't stay in contact. When the cam does rotate on the right, it appears only the cam is moving and it doesn't appear the axle moves so I think the wheel is still linied up on both sides. Any suggestions?
2009 Road Glide
Black Pearl, ABS, Security, and Cruise
Stage 1 A/C, download, and SE Slipon's
S&S Flywheel-balanced and welded
Timken Bearings in the case
Progressive 412 12" shocks
2011 Seat.
jcanrun is offline
post #2 of 12 (permalink) Old 12-17-2010, 08:55 PM
Towerhog
Guest
Posts: n/a
Go to your HD dealer and get a new cam. The cam you have may have too much play in the slot on the axle allowing it to move as you tighten the nut. PN 41819-02.
post #3 of 12 (permalink) Old 12-17-2010, 10:17 PM
I have 35K on my 08 and never had to adjust the belt . The rear tire last between 10K & 15K and when the tire is changed the Tech has to adjust the belt tension at that time . The belt is made from Kevlar and should not stretch to much . Your belt should last around 70k under normal use . IMO don't worry about the belt tension it will be adjusted every time you get a new tire on the rear .
post #4 of 12 (permalink) Old 12-18-2010, 10:38 AM
Roadie09's Avatar
Clean the cam plate with brake clean to remove any grease or lube that might be on it, put a small dab of never seize on the back face of the cone nut. When you torque down the nut, the never seize will keep it from digging into the cam plate and turning it.
Roadie09 is offline
post #5 of 12 (permalink) Old 12-18-2010, 12:09 PM Thread Starter
I'll try your idea as it makes pretty good sense. I think that's exactly whats happening cause when I'm just about at full torque, the cam then moves, kind of spins a little, but the axle doesn't move so the belt tension doesn't change.
2009 Road Glide
2011 Seat.
jcanrun is offline
post #6 of 12 (permalink) Old 12-18-2010, 12:11 PM Thread Starter
I check and adjust the belt myself. I found that the dealer tends to adjust the belt too loose, probably because when the bike is in there, the bike is at operating temperature. I adjust my when the bike is dead cold. I just changed my rear tire at 18,700 miles (this is the original tire) so I'm getting great mileage out of my tires. I last had to adjust the belt around 3000 miles or so.
2009 Road Glide
2011 Seat.
jcanrun is offline
post #7 of 12 (permalink) Old 12-18-2010, 12:36 PM
Roadie09's Avatar
I wish it were my idea, it is actually straight from the repair manual. I was having the same issue you are having until I went back and re-read everything. The never seize will solve your problem.
Roadie09 is offline
post #8 of 12 (permalink) Old 12-19-2010, 02:22 PM Thread Starter
Yup, did this last night and it worked! Thanks for the help. I've got the service manual but just glossed over that part.
2009 Road Glide
2011 Seat.
jcanrun is offline
post #9 of 12 (permalink) Old 09-18-2014, 09:40 AM
This seems to be a fairly common that many diy riders have. Most riders have the bike up on a lift when they put the final torque on the bolt. This will often times result in a space between the cam and the frame on the right side. The solution is to drop the bikes rear tire down on the floor when you torque it up. This seems to keep everything in place. Bye the way, it took me a while to discover this. It damn sure doesn't mention any of this in the shop manual.
96349 is offline
post #10 of 12 (permalink) Old 09-19-2014, 11:28 AM
chromedome's Avatar
It's easy to miss in the service manual, because it is not included in the belt adjustment section, only the rear wheel installation section.
When I do a belt adjustment I do not remove the E-clip, so putting anti-seize on the cone nut is difficult if not impossible.
2012 Road Glide Ultra (SOLD) & 2015 BMW R1200RT
chromedome is offline
2018 RGS rear shock adjuster relocation. wardmj2 Suspensions 28 11-16-2017 01:54 PM
Right place. Right time. RFG7680 *General Road Glide Discussions/Pictures 10 09-24-2016 11:45 PM
Baker Atitude Adjuster - manual primary chain adjuster modot66 Parts for Sale 1 06-19-2014 04:19 PM
Right side 7.25 left side 5.25... Trak350 Audio 3 06-09-2014 10:28 PM
