2018 RGU can not change songs on iPod. - Road Glide Forums
post #1 of 11 (permalink) Old 01-08-2019, 01:51 AM Thread Starter
Worked fine till today now I can not change songs back and forth on the iPod. Button works for volume and changing radio stations but not for changing songs on the iPod. Any ideas ?
2016 Road Glide Ultra Superior Blue
freedom1974 is offline
post #2 of 11 (permalink) Old 01-08-2019, 06:25 AM
Haven’t run into this personally. But have noticed that the system occasionally doesn’t function from one startup to the next. But then will work correctly again.
Have you tried it since the issue occurred? It obviously could be a bad switch, but I would also try restarting your iPod device as well.
I’ve noticed that for most devices and even my 2017 RGU the best tech support has been “turning it off and turning it back on again”.
Jeremy (Gulf Tango)
2017 FLTRU
gtmedic is offline
post #3 of 11 (permalink) Old 01-08-2019, 06:26 AM Thread Starter
I turned it off and rebooted the system and it did not fix it. I will unhook the iPod and try that.
post #4 of 11 (permalink) Old 01-08-2019, 08:57 AM
texasnurse's Avatar
Change the settings in Menu to seek
texasnurse is offline
post #5 of 11 (permalink) Old 01-08-2019, 09:01 AM Thread Starter
In the iPod menu ?
post #6 of 11 (permalink) Old 01-08-2019, 09:03 AM
texasnurse's Avatar
Originally Posted by freedom1974 View Post
In the iPod menu ?
Radio menu.
I have to do this if I have my iPhone connected via usb.
post #7 of 11 (permalink) Old 01-08-2019, 09:44 AM
Paul's Road Glide's Avatar
@freedom1974 I know your fix. I haven't quite figured why it does it but I know how to fix it.
The left menu/toggle button, hold it down until you get the 4 way navigation screen then hit it again to toggle back to the radio. I think I notice this when I go to move something on my GPS screen.
Paul's Road Glide is offline
post #8 of 11 (permalink) Old 01-08-2019, 11:36 AM
Heavy Metal's Avatar
Go into menus find seek ect make sure those are all correct to play next song not repeat song. Hit it by accident. And would not change till changed that setting.
Heavy Metal is offline
post #9 of 11 (permalink) Old 01-08-2019, 11:46 AM
geo8866's Avatar
If all the setting on the bike are correct, plug the ipod into your computer and update it. I had an ipod that stopped working once. I had to uninstall and reinstall the software.
geo8866 is online now
post #10 of 11 (permalink) Old 01-08-2019, 08:12 PM Thread Starter
That fixed it. Thanks a ton !
ipod help jzimmerer Audio 7 02-24-2015 03:58 PM
iPOD not Respond on CVO RG hoser6868 Audio 20 07-16-2013 10:27 AM
HD Audio iPod Interface Install - 2011 RGC wachuko Do-IT-Yourself 26 12-31-2012 07:30 PM
iPod Nano holder installed WoodyHD Aftermarket Accessories 16 02-20-2012 07:07 PM
iPod Touch works well with iPod module philmartin *General Road Glide Discussions/Pictures 2 03-22-2011 07:55 PM
