Check engine light after new bars - Road Glide Forums
 8Likes
post #1 of 13 (permalink) Old 01-13-2019, 11:55 AM Thread Starter
Turbo18's Avatar
I installed new bars and heated grips and now the engine light is on. I have an 18 RGS. Does anyone know off hand what it might be or how to fix it? Thanks.
Turbo18 is offline
post #2 of 13 (permalink) Old 01-13-2019, 12:19 PM
BigBlockBobby's Avatar
Normal if you didn't disconnect the battery first. Try disconnecting the battery for a min. If it comes back you may have a bad connection, cut wire, forgot to plug something in, or a chaffed wire.
Turbo18 likes this.
BigBlockBobby is offline
post #3 of 13 (permalink) Old 01-13-2019, 12:27 PM
JSDonaRGU's Avatar
First reinstall the original bars, if the light goes out you know that the problem is.
Actually I remember this article FuelMoto to reset codes. If you did not disconnect the battery you might of tripped a code on accident. I would start with a resetting the codes.
Hope it helps.
Turbo18 likes this.
My Mods: Vance and Hines FP3, Arlen Ness Big Sucker Stage 1, Legend Suspension Revo-A
JSDonaRGU is offline
post #4 of 13 (permalink) Old 01-13-2019, 12:35 PM Thread Starter
Turbo18's Avatar
Ill try disconnecting the battery and hope that solves it! Thanks guys.
Turbo18 is offline
post #5 of 13 (permalink) Old 01-13-2019, 12:45 PM
RGKen's Avatar
You don't need to disconnect the battery. Just clear the codes. You should have pulled the main fuse before you disconnected the speedo and tach. That is the reason the check engine light is on because it threw some codes for that. Once you clear them the check engine light should stay off unless you have something wrong.
crazy4ink and craigffb like this.
2018 FLTRXS
RGKen is offline
post #6 of 13 (permalink) Old 01-13-2019, 12:48 PM Thread Starter
Turbo18's Avatar
Awesome! thank you very much. I'll give that a shot tonight. Really appreciate the info.
RGKen likes this.
Turbo18 is offline
post #7 of 13 (permalink) Old 01-13-2019, 02:12 PM
craigffb's Avatar
Turbo18 likes this.
craigffb is online now
post #8 of 13 (permalink) Old 01-18-2019, 02:57 PM
Taz_FL's Avatar
This is correct, I ran into the exact same thing after installing new bars after christmas. All you have to do is clear the codes and your issue is solved.
SharknoseScott and jimAZ like this.
Taz_FL is online now
post #9 of 13 (permalink) Old 01-18-2019, 03:01 PM
jimAZ's Avatar
The fuelmoto page above tells you exactly what to do No big deal.
Hello from Arizona
2018 RGU - First Harley, Long time Rider
jimAZ is offline
post #10 of 13 (permalink) Old 06-21-2019, 08:31 AM
How do you clear the codes?
BlackknightRGS is offline
Tags
bars , engine light
Buky Bars - Product Review redbeard719 Controls & Handlebars 20 10-29-2013 06:50 PM
check engine light mdjr47 ECM/Fuel Management systems 7 07-06-2013 08:48 AM
Check engine light bigtommy55 Controls & Handlebars 1 06-28-2013 10:25 AM
FuelPak Check Engine Light Question Pablo22 ECM/Fuel Management systems 12 05-24-2012 12:44 PM
Oil Overfill and Check Engine light Biker Tom Troubleshooting for Road Glides 5 09-15-2010 07:01 AM
