Voltage Issue - Road Glide Forums
 4Likes
post #1 of 21 (permalink) Old 01-29-2019, 08:08 AM Thread Starter
Mulchman's Avatar
Voltage Issue
So the last two times I have been riding the 2012 Road Glide Ultra I have notice the voltage
intermittently fluctuating. First time it dropped to 11.4, and then after 15min it spiked up to 14.7.
It stayed that way the rest of the way home. Second ride (most recent) it dropped to 12.1 and stayed there for a good 6min of highway driving before it rose up to 14.2. I checked to battery and performed
the stator test. Both seem in order, so I am suspecting it is the Voltage Regulator. I read up on some forum posts here and it seems others with the 12's have also had the same issue. RMStator has a
(upgraded) voltage regulator for $129. Has anyone had any experience with RMStator. Not real crazy
about spending the money on an issue that is intermittent, but I dont want to buy a $40 Ebay regulator
that is probably from China.
Mulchman is offline
post #2 of 21 (permalink) Old 01-29-2019, 08:21 AM
hd4cruzin's Avatar
Sure sounds like the voltage regulator. I have a 2012 as well they had a recall on them when they first came out and mine was replaced. Then 5 years later while traveling across country ran into the same issue you are having. Pulled into a dealer and had it replaced.
Sorry canít help on the make of regulator you are looking for but you should replace soon before you get caught on the side of the road.
Good luck
2012 FLTRX BBP
hd4cruzin is offline
post #3 of 21 (permalink) Old 01-29-2019, 08:37 AM
JayKS's Avatar
I've not heard of RMStator, but personally when I have to replace a stator or regulator, I go with Cycle Electric. Very solid stuff.
According to CE's website, CE-608 would be the one for your bike: http://www.cycleelectricinc.com
It's available on Amazon, just search for CE-608.
You can find it other places as well. PhatPerformance, Direct Cycle Parts, etc.
Good luck with getting it resolved. Cheers. -Jay
Mike U and duglauraflht like this.
JayKS is offline
post #4 of 21 (permalink) Old 01-29-2019, 12:42 PM
Mike U's Avatar
Iíll second what Jay said!
I have a 2012 Custom and replaced the stock VR with a Cycle Electric one about 2 years ago just for preventive measures. I have since purchased a Cycle Electric Stator that I will be putting in come Spring, just because.
Mike U.
USMC 1975-1977
Semper Fi!
Nothing else matters!
Mike U is online now
post #5 of 21 (permalink) Old 01-29-2019, 02:41 PM
Good luck
Bad VR can take out a good battery also.
Mike U and Trendkill like this.
post #6 of 21 (permalink) Old 01-29-2019, 04:31 PM
kiwidave's Avatar
Since the alternator system came in for Big Twins at the start of the 1970s, regulators have been the WEAKEST point on our bikes.
Cycle Electric makes a top-quality product.
Cheaper ones can be bad out of the box, yes, even brand new.
I have to smile at folks who observe that that they have had 2 go down in 5 years. That's actually really good.
Here's a tip: since adding an EXTRA earth wire from regulator mount bolt to nearby ground i.e. forward control / footpeg / floorboard mount bolt, I have not had a regulator fail on either of my Shovelheads in the last 7-8 yrs. Before then, it was almost an annual event.
Gary is right ^^^^^ trickle-recharge and then check your battery, as the failed regulator may have caused permament damage.
kiwidave is online now
post #7 of 21 (permalink) Old 01-29-2019, 06:16 PM
My 2 cents with a 12 ultra. Voltage did the same for me for some 3 weekends. Fourth weekend while on a 2 day trip, voltage dropped below 10. Stopped for coffee and bike never started. A AAA tow job to nearest Harley dealer, turned out to be the battery. Twenty-five minutes later I was back on the road.
antant is offline
post #8 of 21 (permalink) Old 01-29-2019, 06:46 PM
Road dawg's Avatar
New to this information, is it the 2012s that had issues only? I have a 2011 FLTRX with 36k and the original voltage regulator and I have two long trips planned this summer you guys got me thinking? I know some of the issues were from the heat of the oil cooler, but my 96 inch does not have one, wonder if this is a factor as well.
Road dawg is online now
post #9 of 21 (permalink) Old 01-29-2019, 06:54 PM
Road dawg's Avatar
Originally Posted by Mike U View Post
I’ll second what Jay said!
Mike U.
How many miles did you have on your scoot when you replaced it?
post #10 of 21 (permalink) Old 01-29-2019, 07:03 PM
Mike U's Avatar
Originally Posted by Road dawg View Post
How many miles sis you have on your scoot when you replaced it?
RD I think it was in the neighborhood of 15,000 miles. I have over 30,000 on her now.
Mike U.
USMC 1975-1977
Semper Fi!
Varying voltage Joesquid Troubleshooting for Road Glides 29 09-11-2017 01:16 PM
BDL enclosed primary installation issue hawk06Glide Engine Related 7 04-10-2017 12:13 PM
Volume Fluctuates sdjiggs Audio 12 09-18-2015 02:20 PM
Voltage problems.... kouack Troubleshooting for Road Glides 17 09-03-2015 07:04 AM
Charging Issues - Voltage Reg AGAIN?! TracknTail Troubleshooting for Road Glides 3 10-07-2013 11:04 PM
