Ignition Switch Problem - Road Glide Forums
 13Likes
post #1 of 36 (permalink) Old 02-28-2019, 06:32 AM Thread Starter
KevDillow's Avatar
Hello, I am in the process of installing new bars and when I went to put everything back on, the ignition switch seems to be misaligned or broken. I've done a search and found that it's easy to fix on the pre-Rushmore models, but mine is a 2016. Do I need to buy the expensive tool or can I still fiddle with it with a screw driver or copper pipe? It will turn and click like normal but nothing happens, but if I push it further down then everything works as it should, but it doesn't click and it's not easy to turn. Hopefully it's not stripped or something if that's possible.
Also, when I was reinstalling everything I noticed some brake fluid leaking from the reservoir by the lever, is this normal since it was hanging or do I need to replace all that stuff now too
KevDillow is offline
post #2 of 36 (permalink) Old 02-28-2019, 06:36 AM
RGKen's Avatar
Originally Posted by KevDillow View Post
Hello, I am in the process of installing new bars and when I went to put everything back on, the ignition switch seems to be misaligned or broken. I've done a search and found that it's easy on the pre-Rushmore models, but mine is a 2016. Do I need to buy the expensive tool or can I still fiddle with it with a screw driver or copper pipe? It will turn and click like normal but nothing happens, but if I push it further down then everything works as it should, but it doesn't click and it's not easy to turn. Hopefully it's not stripped or something if that's possible.
It's just as easy to get it mis-aligned on a 2016 as it is on a 2010. There are YouTube videos on how to make a tool out if copper tubing or you can try the flat blade screwdriver.
2018 FLTRXS
RGKen is offline
post #3 of 36 (permalink) Old 02-28-2019, 06:40 AM Thread Starter
KevDillow's Avatar
Oops sorry I just meant it seemed easier to fix on the pre-Rushmore. I read somewhere that someone thought they changed it for the 2015+ models to where you couldn't use the screwdriver trick anymore. Hopefully that's fake news I really don't wanna spend near $100 on a tool lol
post #4 of 36 (permalink) Old 02-28-2019, 07:42 AM
BH#103's Avatar
If it isn't working out to get it realigned, just remove the switch completely and disassemble it, align it and reassemble. I personally have found it easier to just do that than to fight with it on the bike. It's easier than you might think, just pay attention when you do it and all will be good and it will go back together without an issue.
KevDillow likes this.
"SLIVER"
BH#103 is offline
post #5 of 36 (permalink) Old 02-28-2019, 08:20 AM
RGKen's Avatar
I have also had success looking down through the switch with a flashlight and could tell where the gaps were on each section. Then look at the stem that is out and used a screwdriver to as closely as possible match each section to the stem. Then put the stem back in and Wala. That was on my 2012 so not sure if you can on a 2016. Don't really see why you can't because the stem goes in the same way.
2018 FLTRXS
RGKen is offline
post #6 of 36 (permalink) Old 02-28-2019, 11:38 AM Thread Starter
KevDillow's Avatar
Well no matter how I spun it with the screwdriver, it still will not work no matter what I do. I feel like something is broken. I guess i'm gonna have to get it towed to the dealership :|
post #7 of 36 (permalink) Old 02-28-2019, 12:15 PM
BH#103's Avatar
Or, just remove the switch, split it and realign it. If it helps you out you are not too far from Chicago. Take the switch out and send it to me. I'll get it realigned for you no problem. Happy to help if I can.
RGKen and KevDillow like this.
"SLIVER"
BH#103 is offline
post #8 of 36 (permalink) Old 02-28-2019, 12:16 PM
glidedawg's Avatar
take it out and do it on the bench before the stealership has a crack at ya bro......
Industrial gray denim 2019 fltrxs
Bassani r/r 2-1
RIDE ON
glidedawg is offline
post #9 of 36 (permalink) Old 02-28-2019, 12:38 PM Thread Starter
KevDillow's Avatar
That's awesome thank you I appreciate it! Is that something that is hard to do? I ordered the stupid tool for the hell of it just to see if it makes a difference. I can't even get the switch to lock into place anymore though lol
post #10 of 36 (permalink) Old 02-28-2019, 12:41 PM
BH#103's Avatar
I cannot tell you for sure if the tool will help at this point. The tool is meant to keep it aligned, not too sure about realigning.
"SLIVER"
BH#103 is offline
Removing your ignition switch joke Do-IT-Yourself 21 01-05-2019 02:18 PM
Electronic Security Alarm Flashing and Security Alarm Chirping When Ignition Switch I aklowrider Troubleshooting for Road Glides 2 05-03-2016 02:26 AM
Ignition switch problem ridingalone71 Forum Help Desk (Post Forum Issues Here) 4 04-26-2016 07:39 AM
Can't get ignition switch back in. Diverrick Controls & Handlebars 4 04-15-2016 10:58 PM
Help removing ignition switch. Switch seems stuck? Driftah Controls & Handlebars 5 11-04-2015 07:18 AM
