Sticking Throttle Grip Solution - Road Glide Forums
  • 1 Post By KevDillow
post #1 of 6 (permalink) Old 03-06-2019, 12:18 PM Thread Starter
KevDillow's Avatar
So among other problems I ran into while installing my new bars, my new Avon grips were sticking pretty bad on the throttle side. I did some searching and someone suggested making a tool. They said they used a dowel rod, cut it and put some sandpaper in it to put in a drill. I did that, and it worked great, so here's a picture for anyone else that may have this problem. I got a dowel road at Home Depot for like 80 cents, and some emery paper and sandpaper. Cut a slit in the top (be careful, it broke and I cut my finger open lol) then I folded the sandpaper up into a cylinder shape to fit inside the grip, and honed out the inside using the drill.
KevDillow is offline
post #2 of 6 (permalink) Old 03-06-2019, 12:37 PM
craigffb's Avatar
You sure you didn't just have the grip/hand control pushed to far onto the bar? There should be some play in the grip on the throttle side of the bar.....ie: you should be able to move the grip back and forth a little on the bar.
craigffb is online now
post #3 of 6 (permalink) Old 03-06-2019, 01:05 PM Thread Starter
KevDillow's Avatar
Yeah it was on correctly, I guess it's a common problem with those grips. Used the home made tool and it works great now
craigffb likes this.
post #4 of 6 (permalink) Old 03-06-2019, 02:19 PM
wevsspot's Avatar
Very common problem when using aftermarket bars. I experienced the same myself on two different sets of Avon Grips. By far the worst were the Avon Air Cushion grips.
wevsspot is offline
post #5 of 6 (permalink) Old 03-06-2019, 02:25 PM
Glidin2013's Avatar
Originally, thought I had the same problem when I put mine on. Did not believe it, and didn't think about it. My problem wound up being that the notch end of the bars was slightly spread. I could take my finger and flick the grip and it would slide easily to a certain point. Sanded the grip area on bars and same thing. Now the problem may have been imperfection on the interior of grip, but when I pinched the splits on the bar ends a bit with the grip sensor installed and not damaging the grip sensor. It was just a very slight closing of the spread on the notch of the bars, the grip slid on like a dream. Just my experience. May help somebody.
Glidin2013 is offline
post #6 of 6 (permalink) Old 03-06-2019, 02:32 PM Thread Starter
KevDillow's Avatar
Haha those are the exact grips
2016 FLTRU has smaller diameter throttle grip? RoadRider Controls & Handlebars 0 08-15-2016 07:34 PM
How To Adjust Throttle Free Play And Why Motorcycle.com *General Road Glide Discussions/Pictures 1 03-14-2016 11:25 AM
Throttle grip doesn't rotate easily BrewCitySinner Controls & Handlebars 17 02-08-2015 12:32 PM
Throttle sensor sticking...no, it's not the grip! DC-3Mek Controls & Handlebars 12 10-13-2012 10:56 PM
Poor Acceleration 2BWILD Troubleshooting for Road Glides 17 08-19-2010 04:09 PM
