2018 RGS Error Code PO572 - Road Glide Forums
 16Likes
post #1 of 19 (permalink) Old 04-08-2019, 03:09 PM Thread Starter
Just got out for a little bit today to dust off the ole scoot and I noticed my security light was staying solid red. I found a good place to pull over and checked my codes and I threw a PO572 code and I also had a longer scrolling code that was Pn 41000521C.
I know that the PO572 is a "brake light low", but I am unsure of what the scrolling code is. After getting home, it looked like I had plenty of fluid in my reservoir, however I do not have any breaklights on the rear of the bike. I have running and turn functions, but no brake light function from either brake lever.
For those with some knowledge, could this be a wiring issue under the seat, a pinched handlebar wire since I changed bars over the winter or could this be the Custom Dynamic Module for my rear bag lights that went bad? I don't have any electrical testing equip., however the bike is still under warranty... I just don't want to ride it in if it's an easy fix or most likely something with the CD module.
RoadglideinMO is offline
post #2 of 19 (permalink) Old 04-08-2019, 03:28 PM
craigffb's Avatar
It shouldn't be a wire in the bars or you'd still have light front the rear pedal. That fact that it's no brake period would lead me to believe it's some other issue. I'd start by unplugging the CD module.
RoadglideinMO likes this.
craigffb is online now
post #3 of 19 (permalink) Old 04-08-2019, 03:30 PM
RGKen's Avatar
That longer number is not a code it is the part number for the section you are in. ECM, BCM, ABS Module etc.... They all show that.
2018 FLTRXS
RGKen is online now
post #4 of 19 (permalink) Old 04-08-2019, 04:16 PM Thread Starter
Unplugged the CD module and reconnected the stock harness- still no brake lights on the rear. They are lit as running lights and I also have turn signal function, just no brake lights. The same goes for the Sequential Bag lights.... they are on as running/turn lights, but I have no brake lights.
Thanks guys for the quick replies!
post #5 of 19 (permalink) Old 04-08-2019, 05:33 PM
BH#103's Avatar
What are the most recent modifications you made and can you confirm the lights worked before that? Here is some attached info for your P0572. Hope this gets you in the right direction. Quality is the best I can do right now.
File Type: jpg MVIMG_20190408_173055_1554762718486.jpg (429.6 KB, 17 views)
File Type: jpg MVIMG_20190408_173044_1554762767212.jpg (7.27 MB, 16 views)
"SLIVER"
BH#103 is offline
post #6 of 19 (permalink) Old 04-08-2019, 05:34 PM
BH#103's Avatar
Sorry man, just remembered you said you didn't have any testing equipment. Good literature and a picture to look at on the shitter then.
"SLIVER"
BH#103 is offline
post #7 of 19 (permalink) Old 04-08-2019, 06:12 PM
BH#103's Avatar
Here's another thing to try, no tools required this time I swear. Turn ignition on and press the cruise control enable. Turn ignition off. Hold cruise SET switch on while turning the ignition switch back on. Now you should be in diagnostic mode for the cruise control signals. Anything activated that's involved with the cruise will turn the cruise light green. Check to see if the bike is capable of seeing the brake inputs at least. Could end up being a bent or pulled out pin on the harness. You never know. Even though it's under warranty it's nice to learn new things to arm yourself for future problems.
"SLIVER"
BH#103 is offline
post #8 of 19 (permalink) Old 04-09-2019, 09:08 AM Thread Starter
I wasn't able to engage cruise control on my ride yesterday afternoon at all once the codes showed up. I tried your recommendation this morning, but the cruise light would not change to green at all- it simply stayed the amber color no matter what I tried.
I took off the CD module once again just to confirm what was going on- with just the bike harness connected, I have rear turn signals, running lights. My rear hazards do not activate nor do the brake lights. All the turn/hazard lights on the front of the bike work accordingly. I then hooked the CD module back up and confirmed the same errors and it was all the same. I have turn signals/running lights on the rear lights and bag blades, but no brake lights or hazards. The front of the bike has turn/hazards to the turn signals and windshield blades.
I also pulled the main fuse and reinstalled just as a last resort to try- once the main fuse was reinstalled, the same problems exist.
I have an appointment with my Harley shop to have it looked at, but i'm looking at about 2 weeks before they can get it in since they are so busy this time of year. I'll keep everyone informed and let me know if anyone else has had similar problems or a potential fix for me to try!
post #9 of 19 (permalink) Old 04-09-2019, 11:46 AM
RGKen's Avatar
Did you have the switch housing off for any reason like changing grips or levers? If you did and didn't shim the front brake lever as you took the housing apart and reassembled you could have broken the front brake switch. This would explain no cruise.
2018 FLTRXS
RGKen is online now
post #10 of 19 (permalink) Old 04-09-2019, 11:52 AM Thread Starter
Yes, I have changed bars and grips.... however I have ridden the bike numerous times since then and I did not have any issues prior to yesterday. Though, I would think if that was the cause, I would still maintain the brake light function on the foot pedal?
I have no rear brake lights from either the lever or pedal and I also have no rear hazard lights or cruise.
Arnott Releases 2018 Motorcycle Products Catalog ArnottInc Suspensions 0 02-22-2018 08:37 AM
New member and new 2018 CVO RG! fgregory New Members Welcome Area 25 11-01-2017 06:24 PM
