Fuel spray - Road Glide Forums
 11Likes
  • 8 Post By snarley53
  • 2 Post By Stoic Joker
  • 1 Post By Otter56
post #1 of 9 (permalink) Old 04-11-2019, 12:28 PM Thread Starter
Fuel spray
I recently changed out the pump, filter, regulator, and all hoses, and that is when this started. When I first turn on the ignition I get the priming sound, then it goes quiet. Soon as I start the bike I get the spraying sound, but it goes away once the tank is down to about 3/4 full; not sure if it actually stops spraying or what, but I hear no spray sounds.
I was reading that this could be normal discharge from the regulator? I are confused.
The bike is a 2011 FLTRX and runs great, starts easy, no surging, no popping.
Any suggestions are appreciated.
Otter56 is offline
post #2 of 9 (permalink) Old 04-11-2019, 01:22 PM
snarley53's Avatar
you need louder pipes, then you won't worry about little sounds.
2011 roadglide ultra.2000 93" s&s rigid panhead,
40 ford rat rod pickup
snarley53 is offline
post #3 of 9 (permalink) Old 04-11-2019, 01:46 PM
Stoic Joker's Avatar
If I had to guess - which I do... - I'd say the "spraying sound" is the fuel coming out of the bypass that is hitting the fuel in the tank when it's full, and the side of the tank (much quieter) when the level goes down a bit. Kinda like peeing in a urinal is quieter than peeing into the water in a toilet..
...And you totally need louder pipes.
snarley53 and Otter56 like this.
Scarlet Red 2010 Road Glide Custom named Trixie - She's a flashy little minx..
Basic black 1981 Tour Glide Classic named Alice - She's a sleeper project.
Stoic Joker is offline
post #4 of 9 (permalink) Old 04-11-2019, 02:45 PM Thread Starter
Louder pipes!!! I forgot about that...I keep thinking these problems are something majorly wrong...doh!
snarley53 likes this.
Otter56 is offline
post #5 of 9 (permalink) Old 04-11-2019, 03:29 PM Thread Starter
What I don't get is why it only sprays when the engine is running? You would think that if there was a leak somewhere it would spray whenever the pump is on, since there is no way the system knows the engine is running...there I go thinking hard stuff again.
Otter56 is offline
post #6 of 9 (permalink) Old 04-11-2019, 04:04 PM
BH#103's Avatar
Post a video with sound.
"SLIVER"
BH#103 is offline
post #7 of 9 (permalink) Old 04-11-2019, 08:18 PM Thread Starter
Thanks for they replies guys - yes, I think it is discharge from the regulator. I opened up the lid and watched it as I turned the ignition on and it did spray out of the bottom of the regulator, so makes sense that the sound is from that. I am gonna try a different regulator next as this is a new one and the noise wasn't there before and maybe this one is gooned up.
I am having trouble getting me phone to recored audio, so can't post that yet, will do if this doesn't clear up.
Otter
Otter56 is offline
post #8 of 9 (permalink) Old 07-18-2019, 07:32 AM
When I fill with fuel it does same I just quit worrying about it
post #9 of 9 (permalink) Old 07-18-2019, 02:41 PM
Bleachey's Avatar
I just pulled apart and put back together my fuel system 3 times (when I didn't need to, it was another problem).
Anyway, One of the times I noticed the small o-ring stayed in the plastic housing when I pulled the regulator out, plus I had the screen/bir or-ring and that stuff in the wrong order. You might want to double check to see if everything is there, not too much is there, and that they are out together in the right order, but then again never forget I am an idiot and other people might not have that problem.
I was also told to make sure the hose on the right side of the tank was snapped into the holder and positioned so the end was down towards the front of the tank.
I spent way too much time inside the tank.
2011 Road Glide Ultra
Bleachey is offline
Filler Neck? Deadstroke *General Road Glide Discussions/Pictures 17 04-06-2014 03:10 PM
*New* $199 Fuel Moto Micro Tuner by Dynojet fuelmoto Fuel Moto 8 02-13-2014 12:19 PM
Fuel Moto Micro EFI Tuner install and review Garemlin ECM/Fuel Management systems 21 06-28-2013 04:50 PM
Fuel filter shell recall - theres still a problem Sincecrazy *General Road Glide Discussions/Pictures 2 07-04-2011 11:30 AM
Annoying Fuel Spray Timinfla2 *General Road Glide Discussions/Pictures 43 05-14-2011 12:56 PM
