V INERR starting issue - Road Glide Forums
post #1 of 3 (permalink) Old 05-07-2019, 09:35 AM Thread Starter
Hello all,
2015 RG, having some slow starts and occasionally i get the V INERR code on the odometer. I've been struggling with this for a while and I bought a new battery in 2017, which worked for a while but now I'm having the same issue. I do use a battery tender and I remove and charge the battery during the winter months. Some things I have considered:
-Buy a new Lithium battery
-slow starts due to colder temps?
-20 min ride to and from work isn't enough to charge the battery?
-must be a draw somewhere? (but no electrical accessories added)
Any help or suggestions would be greatly appreciated!
GFFG13 is offline
post #2 of 3 (permalink) Old 05-07-2019, 10:36 AM
RGKen's Avatar
Originally Posted by GFFG13 View Post
Hello all,
If your battery tender is bad then it could ruin a new battery. I would not buy the Li battery as they are not worth the money on IMO. You can't just leave them on a tender like the standard battery. Some like them but I don't see the real benefit.
2018 FLTRXS
RGKen is offline
post #3 of 3 (permalink) Old 05-09-2019, 04:00 PM
Bruce00's Avatar
Iam with Ken on the value of a Lithium battery. Lead acid batteries can be bought for $100 delivered to your doorstep and last 5 yrs.
If it was me, I would purchase a volt meter and first check your charging voltage and if that c
hecks out, then pull the positive lead off the battery and check for a voltage draw while the bike is shutoff.
2 yrs on a new battery doesn't sound right, unless your luck is like mine, and you got a bad battery.
Good luck
**edited to add**
If you search for VINERR on this site, you'll see what that means. I went thru that last yr with mine
2015 RoadGlide Special
Tuned by Jamie @ Fuel Moto w/Rinehart 2>1
Bruce00 is offline
Tags
battery , electrical , starting , v inerr
Whim issue I have not seen addressed even by Harley and Sena RGFLA Audio 23 10-17-2019 09:46 PM
Sumping issue Uncleford Engine Related 11 08-13-2014 05:37 AM
13 RGU Wheel Issue Read if you have a 2013 Captain13 Wheels and Tires 14 08-03-2014 07:44 PM
Initial starting problem spider445 Troubleshooting for Road Glides 7 03-15-2013 12:14 PM
Clutch issue BaggerBrian Troubleshooting for Road Glides 7 05-31-2012 09:46 AM
