Rear brake vibration - Road Glide Forums
  • 1 Post By UT_Larry
post #1 of 9 (permalink) Old 06-01-2019, 06:40 AM Thread Starter
lfo556's Avatar
Hi all. When i apply the rear brake at slows speeds i get a vibration. This only happens when there is a passenger. When I'm solo no problem at all. Any ideas?
lfo556 is offline
post #2 of 9 (permalink) Old 06-01-2019, 08:21 PM
Check bearings!
2016 Road Glide Ultra
dreeves is offline
post #3 of 9 (permalink) Old 06-01-2019, 08:28 PM
RFG7680's Avatar
Originally Posted by dreeves View Post
Check bearings!
That's where I'd look. That and the rotor.
RFG7680 is online now
post #4 of 9 (permalink) Old 06-01-2019, 08:43 PM Thread Starter
lfo556's Avatar
Thanks. I'll check it out it only has 3500 miles.
lfo556 is offline
post #5 of 9 (permalink) Old 06-01-2019, 08:50 PM
RFG7680's Avatar
Plenty of posts on the other forum with failures under 10k. Funny when I upgraded my rims to the Agitators the wheel install kit came with "upgraded" bearings. So what I got from that is stock is generic. Never know. I do a bearing swap when ever I replace tires. Overkill? Maybe.
post #6 of 9 (permalink) Old 06-07-2019, 03:06 AM
Phantom6722's Avatar
+1 on bearing replacement with new boots.
Cheers Skip
Phantom6722 is offline
post #7 of 9 (permalink) Old 06-07-2019, 05:21 AM
UT_Larry's Avatar
I also replace the bearings at each tire change. Wheels are already off the bike, I would rather change them early and when not needed then have them fail.
RFG7680 likes this.
UT_Larry is online now
post #8 of 9 (permalink) Old 06-07-2019, 01:41 PM
Usually when the bearings start to go bad you may hear a clicking sound when you back up the bike. Jack up the rear or the bike and see if there is any side by side play in the rear wheel. Also see if there is any side by side play in the rear pulley. My other suggestion is that the disc brake pads are vibrating so if you pull the back pads and put disc brake lube on the back of the pads it may cure your problem.
post #9 of 9 (permalink) Old 06-10-2019, 02:40 PM Thread Starter
lfo556's Avatar
Thanks for all the info I'm going to check them some time this week
lfo556 is offline
