Belt slipping? - Road Glide Forums
 14Likes
post #1 of 16 (permalink) Old 06-09-2019, 11:39 PM Thread Starter
Belt slipping?
99. Used the pughco swingarm bushing upgrade kit to spherical metal bushing kit with the new rubber isolator hockey pucks. New belt and new trans sprocket. Also new front motor mount. Under hard acceleration still feels like the belt is skipping across the sprocket. Inspected the belt after 15 Miles and belt still looks new. But still no idea what's going on.. anyone have similar problems and how did you fix it? Or anyone maybe have a clue?
Sent from my SM-N950U using Tapatalk
1fast2liter is offline
post #2 of 16 (permalink) Old 06-10-2019, 08:37 AM
twowheeladdict's Avatar
Welcome to the forum. I am not familiar with all the changes that you made, but I will say that if you have the belt tension correct there is no way the belt could be skipping across the sprocket.
Hopefully someone with experience will chime in.
If all the parts were installed correctly, I am going to guess that your clutch is slipping.
Stoic Joker likes this.
twowheeladdict is offline
post #3 of 16 (permalink) Old 06-10-2019, 08:40 AM
Trendkill's Avatar
I agree w/TwoWheelAddict. Furthermore, if the belt WAS slipping, the evidence would be VERY obvious in your examination of the belt.
Cadman likes this.
2018 Road Glide Special in Bonneville Salt Pearl - Stage II Power, SVT Boneshaker exhaust
Trendkill is offline
post #4 of 16 (permalink) Old 06-10-2019, 11:20 AM
Stoic Joker's Avatar
I've done the spherical bearing conversion a couple of times, they're straightforward and really hard to screw up. So I'm going with your clutch diagnosis, since toothed belts typically only "slip" once as the teeth are shaved off right before they snap...
Scarlet Red 2010 Road Glide Custom named Trixie - She's a flashy little minx..
Basic black 1981 Tour Glide Classic named Alice - She's a sleeper project.
Stoic Joker is offline
post #5 of 16 (permalink) Old 06-10-2019, 12:27 PM Thread Starter
I don't lose speed bike keeps accelerating. And I run a energy one clutch with the extra plate kit. The feeling I get is like the belt is slipping across the trans sprocket. Pic is of old sprocket that belt slipped across. New sprocket is all steel
post #6 of 16 (permalink) Old 06-10-2019, 12:55 PM
RGKen's Avatar
What belt tension are you setting it at. It is far better for the belt to be adjusted to the tight side of spec. I'm with everyone else here in saying that there is no way for the belt to slip across the sprocket unless your tension is way too loose or the belt is worn completely.
2018 FLTRXS
RGKen is offline
post #7 of 16 (permalink) Old 06-10-2019, 01:06 PM Thread Starter
It's set to about 3/8 deflection. Belt is new and both pulleys are new. Clutch is energy one. This dosnt feel like clutch slipping. And bike keeps gaining speed. But the whole time feels like the belt is skipping. And iam just trying to track that down
post #8 of 16 (permalink) Old 06-10-2019, 02:05 PM
Thermodyne's Avatar
3/8th free deflection? Or 3/8th with the tool set to 10lbs?
Thermodyne is offline
post #9 of 16 (permalink) Old 06-10-2019, 02:08 PM Thread Starter
Free I dont have the tool
post #10 of 16 (permalink) Old 06-10-2019, 02:49 PM
Get one, 3/8 free vs. 3/8 10lbs isn't even close. You will either strip or snap the belt running it that loose for to long.
Tool is only about $35 from Harley, or $20 on eBay if your lucky. Belt is about $200 not counting labor.
Get the tool...
RGKen and Trendkill like this.
