2016 FLTRU Vibration - Road Glide Forums
 14Likes
post #1 of 20 (permalink) Old 07-07-2019, 08:52 PM Thread Starter
I have a 2016 FLTRU with 2400 miles. My biggest issue at the moment is about the vibration I feel at 75 miles an hour, @ 3000 RPM. Significant handlebar shake and vibration in floorboards. Touch the air cleaner housing and yes you can feel it. That same vibration present at lower speeds but not as noticeable. Also hear a lot of valvetrain noise.
Maybe picky but seem like this thing should be as smooth as butter past idle.
I also have a rear brake vibration at moderate braking speeds.
Any idea where to start?
swiederin is offline
post #2 of 20 (permalink) Old 07-07-2019, 10:40 PM
BigBlockBobby's Avatar
Check the motor mounts?
BigBlockBobby is offline
post #3 of 20 (permalink) Old 07-08-2019, 06:05 AM Thread Starter
I have not. What should I be looking for?
post #4 of 20 (permalink) Old 07-08-2019, 06:16 AM
eddienelson's Avatar
Dont take this the wrong way but If you dont know where or how to check the motor mounts then maybe you should take it to someone to look at it. Make them show you what they are doing. You can learn a lot from watching. Also at 24k miles how are the tires and brakes. I would suspect they are all new or should be. Good luck with what ever you do. Does it vibrate in neutral with a little throttle applied? Just curious.
RGKen likes this.
2016 RG Custom Vivid Black
eddienelson is offline
post #5 of 20 (permalink) Old 07-08-2019, 10:40 AM Thread Starter
No worries. I do as much as I can but a mans got to know his limitations. The bike has 2400 miles not 24000. I understand that Harleys vibrate but should smooth out with RPM. Seems like this has always had a noticeable vibration but on the interstate this weekend @ 3000 rpm at 75 MPH it was bad. If I took my had off the left grip the bars would shake so bad you could see it.
Somethings wrong but with so few miles it makes me wonder. The bike has lots of power and runs well but that vibration is a beast.
eddienelson likes this.
post #6 of 20 (permalink) Old 07-08-2019, 11:16 AM
wevsspot's Avatar
As others have mentioned, check your tires. That's not a lot of mileage on a 2016 model, so I'd guess that it sits in the same place for long periods of time. Brakes should be good though.
In addition to the motor mounts, check your front and rear wheel bearings.
wevsspot is offline
post #7 of 20 (permalink) Old 07-08-2019, 12:53 PM
RonC26's Avatar
That bike is still new. Iíd take it to a good dealer or indy & let them check it out unless you spot something obvious. Bad vibration at high speed sounds dangerous to me.
geo8866 and skillz213 like this.
ďA ship in harbor is safe, but thatís not what ships are built forĒ - John A Shedd
RonC26 is online now
post #8 of 20 (permalink) Old 07-08-2019, 02:35 PM
Some have found stones or even a bolt or something wedged between the frame and motor. This will send the vibs right up to your bars.
PBSTN, RGKen and ALMOONEY like this.
post #9 of 20 (permalink) Old 07-08-2019, 04:26 PM
RGKen's Avatar
Could have just slung the wheel weights off.
ALMOONEY likes this.
2018 FLTRXS
RGKen is offline
post #10 of 20 (permalink) Old 07-08-2019, 08:16 PM
Keep us posted. Im riding a 16 as well. I had a similar issue but I had 20k miles and needed brakes and tires.
