2019 Road Glide front end clank and vibration - Road Glide Forums
post #1 of 5 (permalink) Old 07-13-2019, 01:17 PM Thread Starter
I have a slight issue with my ‘19 Road Glide Special.
When I’m slowly backing, there is a clank in the front end. Not bad, just pretty noticeable. Now, the bike is not as smooth in the front and when I zig zag down the road to feel the vibration, it’s much worse when I’m leaned than straight.
4K miles. Any ideas before I have to leave it at the dealer for 3 weeks?
Tires are not cupped, they are ran to spec. My guess is brake calipers or steering head adjustment or lube needed.
sking0086 is offline
post #2 of 5 (permalink) Old 07-13-2019, 01:52 PM
RGKen's Avatar
Originally Posted by sking0086 View Post
I have a slight issue with my Ď19 Road Glide Special.
When Iím slowly backing, there is a clank in the front end. Not bad, just pretty noticeable. Now, the bike is not as smooth in the front and when I zig zag down the road to feel the vibration, itís much worse when Iím leaned than straight.
Steering head should have been adjusted at the 1k mile service. The clank is most likely just the brake pads moving in the calipers. That is normal and is fine. The vibration issue could be any one of a thousand things.
2018 FLTRXS
RGKen is online now
post #3 of 5 (permalink) Old 07-13-2019, 06:39 PM
Wheel bearings.
2016 Road Glide Ultra
dreeves is online now
post #4 of 5 (permalink) Old 07-13-2019, 08:16 PM
clank= brake pads. done it on all my bikes... except for the 86 cb
CORider is offline
post #5 of 5 (permalink) Old 08-05-2019, 01:12 PM
Mine is also making a clunky noise.my rotors are loose ! They move back and forth. Back to the dealer next week
Joepaga is offline
