Rebuid Compensator - Road Glide Forums
post #1 of 4 (permalink) Old 12-21-2010, 08:47 AM Thread Starter
mrbill's Avatar
Rebuid Compensator
Has anyone looked into rebuilding a stock compensator using the SE spring pack (83936-09) to solve the issues with the stock compensator? Anyone know why it would not work? Thanks, Bill
mrbill is offline
post #2 of 4 (permalink) Old 12-21-2010, 12:00 PM
The stock compensator has a different ramp angle then the SE compensator , the SE compensator has steeper ramps . The main problem with the stock compensator are the springs & putting stronger springs in the stock compensator would probably help some but the ramp angle is also a problem and contributes to the starter clunk & primary noise . If you take the stock compensator and compare it to a SE compensator you can see the difference , the SE compensator is much better built & a heavier duty part .
You have to take the primary off to work on the compensator so I would put on the SE compensator and know I have put on the better upgraded part that has a positive feed back from those that installed it or you can take a chance on beefing up the stock compensator with the possibly of having negative results IMO .
post #3 of 4 (permalink) Old 01-28-2011, 11:47 PM
tourglide's Avatar
The rotor is different and will not interchange. On the stock one the spring pack is attached to the outside of the rotor anon the SE it is seperate.
tourglide is offline
post #4 of 4 (permalink) Old 01-29-2011, 08:12 AM
HD-DOC's Avatar
I just installed the SE Comp, in my 09 SERG and I have to say it makes a hugh improvement in starter noise and primary chatter. Its a good upgrade for all 07 up bikes. Doc
HD-DOC is offline
New Compensator or Compensator eliminator mrmoto95 Engine Related 11 03-28-2018 08:10 PM
Compensator rattlin' JacktheBagger Road Glide Specific Discussions 19 06-26-2011 12:57 PM
Compensator sprocket tourglide Troubleshooting for Road Glides 13 01-18-2011 02:47 PM
Belt Drive Limited Compensator mrbill Troubleshooting for Road Glides 0 12-19-2010 08:00 AM
SE Compensator Installed HD-DOC *General Road Glide Discussions/Pictures 0 08-06-2010 09:41 AM
