2015 RGS won't turn over - Road Glide Forums
 8Likes
post #1 of 11 (permalink) Old 08-11-2019, 12:27 PM Thread Starter
I'm sure this has been discussed previously but my bike will not turn over. Battery has plenty of juice but when I go to start it, it makes a loud cranking sound but doesn't actually start. Bike JUST came out of service yesterday and now this. Tried to post a video but apparently I can't post videos... Please advise!
U.S. Army, 1997-2003
2015 Vivid Black RGS: S&S Stealth A/C; V&H DD, OS Titans, FP3; MM Ohlins #2ADJ; Biketronics Sound; Clearwater Aux Lights
MaroonRaider is offline
post #2 of 11 (permalink) Old 08-11-2019, 12:48 PM
Mike U's Avatar
Is Your Battery the original OEM one that came with The Glide when You bought it?
If so, it could be going bad.
Did You try connecting a booster pack or battery charger and see if it would start?
If there is any further diagnosis that You have post it up so We can assist You.
Mike U.
Desert Rider AZ likes this.
USMC 1975-1977
Semper Fi!
Nothing else matters!
Mike U is offline
post #3 of 11 (permalink) Old 08-11-2019, 12:51 PM Thread Starter
Thanks, Mike U. It is the original battery. I charged it to its full (according to my Battery Tender 800) capacity but still nothing. According to my FP3 it's at 11.2 volts. All auxiliary electronics work...just won't turn over. I cleaned up the battery terminals, tried again, but still nothing. Battery might be the problem but it not sure. I'll see about getting a replacement.
post #4 of 11 (permalink) Old 08-11-2019, 12:56 PM
Mike U's Avatar
You're welcome Bro.
Even tho the electronics are working it's possible it has a weak cell and at 11.2 Volts that's a little low to crank The Glide.
If You have access to a Battery Charger I would try that and see if it starts with the extra boost.
If it does I would look into a replacement battery.
I purchase my replacement batteries at Battery Mart, I'll post a link below for You.
Best of Luck and let Us know how You make out.
Mike U.
https://www.batterymart.com/?gclid=C...8aAoHSEALw_wcB
USMC 1975-1977
Semper Fi!
Mike U is offline
post #5 of 11 (permalink) Old 08-11-2019, 01:02 PM
Little Wing's Avatar
X2
Battry is toast
Contrary to popular opinion, summer is hardest on battries
Little Wing is offline
post #6 of 11 (permalink) Old 08-11-2019, 01:58 PM Thread Starter
Originally Posted by Little Wing View Post
X2
Battry is toast
You guys rock! And great chart, Little Wing. It was, in fact, the battery. Don't know why I doubted you for a second. Turned right over and made my day. Thought I'd have to drive to work tmw...DC area...pain without the bike. Thanks!!
Mike U and Little Wing like this.
post #7 of 11 (permalink) Old 09-07-2019, 05:11 PM
eddienelson's Avatar
Originally Posted by Mike U View Post
You're welcome Bro.
Mike U.
Any recommendations on which battery from bm? What kind of life are you getting out of them? Im at 3years 7 months on the factory one so its time. I also found a couple of Duracell batteries with 2 and 3 year warranties.
2016 RG Custom Vivid Black
eddienelson is offline
post #8 of 11 (permalink) Old 09-07-2019, 05:20 PM
MisterEd's Avatar
This company makes them for HD.
East Penn Manufacturing | Power sports batteries
ETX30L
ETX30LA
and YIX30L
eddienelson likes this.
MisterEd is offline
post #9 of 11 (permalink) Old 09-07-2019, 06:23 PM
Desert Rider AZ's Avatar
My 15 Fltrx original battery went around 6-7 months ago. I thought it was a bit soon compared to my other Harleys but was told the AZ heat is very hard on those batteries. I got my replacement battery from Battery Mart, like Mike U mentioned. Glad you got your issue solved and it was just the battery
Desert Rider AZ is offline
post #10 of 11 (permalink) Old 09-07-2019, 06:59 PM
Just ordered the big crank. Thanks for the info and the thread.
