Another same old leak - Road Glide Forums
post #1 of 13 (permalink) Old 12-24-2010, 02:39 PM Thread Starter
Redfish-Joe's Avatar
I haven't posted on this before because I have been waiting on the service department's to figure it out. Here is the deal. I am loosing oil from around the oil pan some where. Not tranny oil, not primary oil but engine oil. This is the work that has been done over the last several months.
Slidell HD:
Replace oil pan gasket. (I did find two loose bolts when I got home)
Replaced all inner and outer primary seals twice.
Replaced transmission seals once
Replaced VSS o-ring once.
Mobile:
Replaced bearing in inner primary and seal. (One cause of noisy starting)
Installed SE compensator.
Oil LOOKS like it is seeping from behind the front belt pulley and SEEMS to be blowing back onto the oil pan. Shifter shaft area is bone dry. Oil plug had a new o-ring and teflon on it when installed. That area seems dry all but some mist.
Mobile service dept wants me to bring it back to check it out. No problem there. You guys got any ideas? This has been the same scenario since the leak first started. Bike has 40k on it and has been a problem since about 15k. I use Mobile 1 V-Twin and change every 5k, Spectra 6 speed and change every 10k and Formula plus in the primary and change every 10k.
Redfish-Joe is offline
post #2 of 13 (permalink) Old 12-24-2010, 03:02 PM
RoadGlideRider's Avatar
The surface between the motor and transmission need to be really flat to not leak. The oil that does leak is Motor oil. They might check the mating surfaces.
RoadGlideRider is offline
post #3 of 13 (permalink) Old 12-24-2010, 03:06 PM Thread Starter
Good point. I'll mention that to them next week. Of course the have a PHD an already know that...LOL
Thank and Merry Christmas!
post #4 of 13 (permalink) Old 12-24-2010, 04:11 PM
Took me 4 times to git my 06 streetgide fixed ,it was a worn shifter shaft and seal.
harley99 is offline
post #5 of 13 (permalink) Old 12-24-2010, 04:35 PM Thread Starter
I have 15 pages of service write ups from Slidell HD. Maybe Mobile will get a grip on it.
post #6 of 13 (permalink) Old 12-24-2010, 05:45 PM
have they ruled out porus cases and also have they added a dye to the oil to aid in looking for the leak those are about the only things I can think of that you didnt mention .
Eagle
Eagle is offline
post #7 of 13 (permalink) Old 12-24-2010, 06:10 PM Thread Starter
Eagle
Dye is next on my to do list before I take it in.
Thanks y'all!!
post #8 of 13 (permalink) Old 12-24-2010, 09:13 PM
Carisma Audio's Avatar
try this clean the area really well and dry it then, put baby powder over areas where you think it may be coming from and go for a short ride to get it up to temp then look for runs in the powder maybe this will help out that teck...
Carisma Audio is offline
post #9 of 13 (permalink) Old 12-24-2010, 09:30 PM Thread Starter
Thanks for the tip. I got some dye at Advance Auto Parts. Gonna put in in before I leave for Mobile.
post #10 of 13 (permalink) Old 12-28-2010, 05:04 PM Thread Starter
Took the bike to Mobile today and was there when they tore it down. No engine oil leak according to the black light!! The Shifter shaft seal is good and it appears that the inner primary seal was good also. What we did find was a honking glob of RTV around the VSS and oil in the valley under the starter.
I had speedo troubles on my Ca. trip and got it fixed when I got back home at Slidell HD. The VSS has a o-ring on it and don't require RTV to seal. Hopefully this fixes everything. Thinking back, 6800 mile trip and no leaks until I put it in the shop for the speedo...got to be it!.
Best advice I can give anyone....STAY AWAY FROM SLIDELL HD!!
Another mystery oil leak???? RonC26 Engine Related 18 12-04-2015 04:38 PM
Same old speaker question... dmiller Do-IT-Yourself 15 04-04-2014 08:51 AM
New cam same old tune? Reddobe1 Engine Related 7 08-08-2013 04:55 PM
Oil Leak? Primary Leak? shutzund Troubleshooting for Road Glides 4 06-04-2013 08:55 PM
hey all same old story sanddragonslayer New Members Welcome Area 56 04-21-2013 07:45 AM
