09serg engine light/power loss - Road Glide Forums
post #1 of 27 (permalink) Old 01-08-2011, 11:45 PM Thread Starter
digga25's Avatar
I have been having trouble with my engine light. After the bike is up to temp.If you shut it off and try to restart,the engine light will come back on after the bike is running.At this point there is a loss of power and the cruise controll wont work. After shutting off the bike and cycling the ignition it resets and runs fine. Any thoughts. Appreciate any help on this.
digga25 is offline
post #2 of 27 (permalink) Old 01-09-2011, 07:55 AM
HD-DOC's Avatar
It has a problem. Check the codes it is throwing. Doc
HD-DOC is offline
post #3 of 27 (permalink) Old 01-09-2011, 11:04 AM
Neano62's Avatar
Whats that thing ya gotta do to recycle the High Idle problem?
Sumthin like turning off the bike,like you have stated, then like doing it a couple more times to recycle for the High Idle.
Dont no if that would work, but its worth a thought.
Sumbody will chime in that knows what I'm talkn bout.
That sucks Digga
[/IMG]
Neano62 is offline
post #4 of 27 (permalink) Old 01-09-2011, 06:10 PM Thread Starter
digga25's Avatar
tried checking for codes through the TTS but nothing came up because it was not happening at the time. If the light does not come on it runs fine.
digga25 is offline
post #5 of 27 (permalink) Old 01-09-2011, 07:54 PM
Martinsurg's Avatar
I'm monitoring this thread closely for obvious reasons. I have a PCV and a little over 14K miles and have not experienced this problem, unfortunately i don't have any fixes to add to the discussion.
God Bless & Ride Safe!
Martinsurg is offline
post #6 of 27 (permalink) Old 01-09-2011, 10:04 PM
Martinsurg's Avatar
Don't know if this would help diagnose the problem
http://cgi.ebay.com/ebaymotors/ws/eB...#ht_2715wt_961
post #7 of 27 (permalink) Old 01-09-2011, 10:07 PM
unbalanced's Avatar
Have you cleaned your speed sensor ? I would pull it out and check it. I believe they are around 50 bucks if you need to replace it.
Also have you checked your speedo for codes there? hold in the button for the odometer and turn the bike on hold it i think it is 5 seconds then click through each of the sections to see if any codes are there.
-Unbalanced
He who laughs last thinks slowest.
unbalanced is online now
post #8 of 27 (permalink) Old 01-10-2011, 07:36 AM Thread Starter
digga25's Avatar
Martin, thanks for the link but the TTS should pick up any codes.
Unbalanced would the speedo archive any events,or just pick up during the event, thanks for the help.
digga25 is offline
post #9 of 27 (permalink) Old 01-10-2011, 07:41 AM
HD-DOC's Avatar
The speedo will collect current and historic events, do the speedo check first. Doc
HD-DOC is offline
post #10 of 27 (permalink) Old 01-10-2011, 07:45 AM Thread Starter
digga25's Avatar
Thanks Doc I will check that
digga25 is offline
Riding home-loss of power BlueGlide12 Troubleshooting for Road Glides 15 08-15-2013 06:28 AM
Loss of power / wont rev about 2200rpms phillipscmfp Troubleshooting for Road Glides 3 06-18-2013 09:45 AM
power loss hardrock Engine Related 14 05-19-2013 11:09 PM
intermintent power loss spshult Troubleshooting for Road Glides 0 05-27-2012 08:40 PM
Loss of Mileage, engine seems to be 'seeking' an RPM, Cruise is failing Timinfla2 Troubleshooting for Road Glides 18 04-26-2011 05:08 PM
