Couple of questions... - Road Glide Forums
post #1 of 6 (permalink) Old 01-24-2011, 10:39 AM Thread Starter
Osuno77's Avatar
Ok, recently changed out handlebars, in the process I had to change out the clutch cable. When removing the clutch cable, I had to remove the cover with "Six Speed" on it. The fluid inside is crank case fluid correct? Or transmission fluid?
Second question, I test fired the bike this morning after working for 5 nights. Everything started fine, save for the fact that the bike jumped on me when I had the clutch lever pulled full back . Is the cable not tight enough or did I screw something else up?
Thanks in advance, electrical I get, mechanical not so much.
Chris
2007 XLC 1200 "Rosie"
2010 Vivid Black Road Glide "Clarice"
Osuno77 is offline
post #2 of 6 (permalink) Old 01-24-2011, 11:55 AM
Gonekat's Avatar
The fluid that came out is transmition or more likely gear oil. As for the lurch when starting, mine does the same if you try to start it cold without putting in Neutral.(which you should not try to make a habit of doing anyway)
Gonekat is offline
post #3 of 6 (permalink) Old 01-24-2011, 06:57 PM
mrbill's Avatar
If you have it adjusted correctly, then it sounds like the clutch plates are sticking together (common). I always work the clutch lever a few times before starting (cold start) to free them up. Yea, transmission fluid (gear oil) is what leaked out.
mrbill is offline
post #4 of 6 (permalink) Old 01-24-2011, 07:08 PM
Carisma Audio's Avatar
Use forumla plus or syn3 the trans or redline. Did you happen to not put the balls inside the cover a little off this sometimes happens
Carisma Audio is offline
post #5 of 6 (permalink) Old 01-24-2011, 07:56 PM Thread Starter
Osuno77's Avatar
Thanks for the replies fella's. Gonna work on it in the morning and will check out all the possibilities.
Osuno77 is offline
post #6 of 6 (permalink) Old 01-24-2011, 09:58 PM
OSUNO77, Just my 2 cents, purchase yourself a HD Manual from your HD dealership about $55. It will be the best investment if you plan on working on your own bike. BUT you can get GREAT INFO here also
Hillglide
Hillglide is offline
JUsta a couple of pics of the bus from the last couple of days! ChromeYellow67 *General Road Glide Discussions/Pictures 31 11-24-2012 11:41 AM
Couple of questions ... fugly1 *General Road Glide Discussions/Pictures 9 11-02-2011 10:31 PM
couple of questions masonc *General Road Glide Discussions/Pictures 22 04-29-2011 01:21 AM
A couple of questions Hollywood Voo ECM/Fuel Management systems 2 04-15-2011 05:56 AM
A couple questions??? RWB427 *General Road Glide Discussions/Pictures 3 12-07-2010 08:44 PM
