Starting failure - Road Glide Forums
post #1 of 7 (permalink) Old 02-11-2011, 01:05 AM Thread Starter
jramy's Avatar
Starting failure
:,Recently on a few occassions while getting ready to start my '08 Roadglide, my signal lights begin flashing and the start button produces "no contact". After several attempts, I finally get it to start with no clue to why this occurred. My brotherlaw has experience the same with a '09 Streetglide. Any hints or like experiences, solutions?
jramy is offline
post #2 of 7 (permalink) Old 02-11-2011, 06:01 AM
HD-DOC's Avatar
Change the battery in your alarm key fob. Doc
HD-DOC is offline
post #3 of 7 (permalink) Old 02-11-2011, 08:30 AM
T-BO 399's Avatar
You can also set up a code that you enter using your blinker switches for when the fob is not working
2009 FLTR, BLACK PEARL
T-BO 399 is offline
post #4 of 7 (permalink) Old 02-11-2011, 10:53 AM
firemanvic's Avatar
Cool
hey T-BO, wow, didn't know that about using the turn signals, I bet that is in the manual, mabe I should read tthe thing.
RGU w/ monster rounds and true duals, SE Ventalator, Dobeck EFI, Cee Baileys Shield, Power-coated heritage bars, Rear facia, detachable tour-pak
firemanvic is offline
post #5 of 7 (permalink) Old 02-11-2011, 11:36 AM
Roadie09's Avatar
I am with Doc, it sounds like a dying key fob.
Roadie09 is offline
post #6 of 7 (permalink) Old 02-11-2011, 03:32 PM
I had a similar problem & changed the key fob battery. For some reason the battery doesn't last that long. Now I pack a spare. just my $.02
Hillglide is offline
post #7 of 7 (permalink) Old 02-11-2011, 04:11 PM
Martinsurg's Avatar
Always a good idea to change the battery in BOTH key fobs, they seem to die at the same time no matter if you are using them equally or not.
God Bless & Ride Safe!
Martinsurg is offline
1400 miles and my first issue - a failure to start. whispanic Troubleshooting for Road Glides 3 08-10-2011 10:53 AM
Clutch Failure Martin Troubleshooting for Road Glides 7 05-30-2011 09:27 AM
Quick detach mount failure? FLTRI *General Road Glide Discussions/Pictures 14 03-29-2011 07:40 AM
Arnott Air ride bracket failure angelfrdad Aftermarket Accessories 4 06-19-2010 08:37 PM
Brake failure pte359 Troubleshooting for Road Glides 14 02-03-2010 04:08 PM
