Spyke starter issues - Road Glide Forums
post #1 of 3 (permalink) Old 02-13-2011, 10:40 PM Thread Starter
Got a spyke for the heritage a year ago and it's had issues
Some times when I hit the start button nothing happens yet I have power at the wire and the electronic comp releases open as they are on the same circuit
I put an override button on the solenoid and it will crank every time
It will do it. Then all of a sudden work. Then it will stop working. Online fuse is 15 and has popped occasionally. But the releases work every time
Here is the plunger
And inside
It did run on one time. So that may have done some of the damage. But it's been a PIA from day one
Pulled it apart and Decided to change out contacts
"My rule of life prescribed as an absolutely sacred rite smoking cigars and also the drinking of alcohol before, after and if need be during all meals and in the intervals between them." Winston Churchill
Hotroadking is online now
post #2 of 3 (permalink) Old 02-14-2011, 11:50 PM Thread Starter
Got new solenoid rebuild and picked up starter relay. So starter is done as far as changing parts
Now on to chasing the big Electric gremlin started by measuring voltage at green wire. 10.46 when starter button pressed
Time to do volt drop test.
Checked the relay slots U which is BK/R from button 10.46
Then check direct voltage from battery at slot E R/BK which is power from main switch. 10.46
Hmm pattern?
Check voltage at power to main switch R red wire. 12.57 so I sm good to the main switch
Turn on main ignition and check R/BK which is feed to starter relay power E 10.46 volts
So it appears that the main ignition may be culprit in that there is a drop right at wire coming out of switch
post #3 of 3 (permalink) Old 02-15-2011, 01:05 PM Thread Starter
Thanks. I have the diagrams in the SM and your tips confirm what I was planning
I pulled both power delivery wires from the connection to the main switch.
Before power in 12.5. Power out 10.4 both sides
Pulled wires out and checked.
12.5 both sides so there is a draw somewhere that has to be found
Next up. Tank off wires back to switch check fuses then check connections yo front controls and lights.
I'm gonna find this sucker.
Starter issues Chromedclassic General Off-Topic Discussions 5 07-11-2018 02:25 PM
Starter Issues 2016CTRoadGlide Engine Related 0 06-26-2018 11:23 AM
2007-2010 Compensator /Starter issues ROADEAGLE *General Road Glide Discussions/Pictures 36 08-24-2012 10:53 AM
Rebuild silenoid or replace starter? krgs2k Troubleshooting for Road Glides 6 04-20-2011 05:01 AM
Starter Marks07RG Equipment-RG 1 09-21-2010 06:42 PM
