Right tool (torque wrench) for the job? - Road Glide Forums
post #1 of 10 (permalink) Old 02-15-2011, 07:55 PM Thread Starter
Govdog76's Avatar
I am planning to buy a torque wrench to help me keep my new orange beauty in good shape, and to check up on the dealer's work. I will not be doing major engine work, etc.
Question is: for most tasks on the bike, is a 10-100 ft/lb, 3/8" drive wrench the right range? I realize there will likely be some big jobs (and perhaps some small ones) that will be outside the range, but I cannot justify having more than one torque wrench, so wanted to know if this was the right jack of all trades?
Thanks
Ian
Govdog76 is offline
post #2 of 10 (permalink) Old 02-15-2011, 08:46 PM
HogWild's Avatar
I've also wondered what would be the best all around torque wrench. Hopefully someone has the answer. What part of NC are you in. I'm in Farmville myself. A hour east of Raleigh.
"No man is rich enough to buy back his past, so enjoy the moment"
HogWild is offline
post #3 of 10 (permalink) Old 02-15-2011, 10:21 PM
pisssed's Avatar
For what Your using it for Your right on target 10-75 ft. lbs., 3/8 in. Drive will do 90% what you need found at sears will work great for you... http://www.craftsman.com/shc/s/p_101...2&blockType=L2
I'm an hour south of Raleigh...
Unstable since the invention of MILF.......
2000 Road Glide
2002 Big Dog Boxer
pisssed is offline
post #4 of 10 (permalink) Old 02-15-2011, 10:39 PM
HogWild's Avatar
thanks for the info.
maybe we can meet up and ride sometime.
HogWild is offline
post #5 of 10 (permalink) Old 02-16-2011, 03:22 AM
masonc's Avatar
make sure you pay attention and don't use foot pounds when it calls for inch pounds. i agree that a 10-75 ft. lbs. 3/8 in drive is good all around but you should also consider getting one in inch pounds as well.
2010 Road Glide Custom
Mods: Windshield, Grips, Shifter Pegs, 2011 CVO SG Seat, V&H Pro-pipe with Klock Werks Super Saver Mufflers, Screaming Eagle Stage 1 Air Cleaner, and misc Live to Ride covers...
masonc is offline
post #6 of 10 (permalink) Old 02-16-2011, 03:58 AM
HD_Shock's Avatar
Yep, there's quite a few specs given in inch/lbs. Ideally, you'd have both ft/lbs and in/lbs wrenches but it's easy to convert ft pounds into inch pounds (and visa versa). If you can only swing one, I'd go with a ft/lbs. wrench. (that's all I have)
-phil
2011 FLTRX 103
HD_Shock is offline
post #7 of 10 (permalink) Old 02-16-2011, 07:17 AM
I have 3 torque wrenches in my tool arsenal, 1/4" inch pound up to 160 made by Proto, 3/8" inch pound Craftsman like the on pissed suggested, 1/2" inch pound Central Tool that I use mostly on autos & trucks. I usually have the Snap-On truck check them out once a year to make sure that are accurate. Keep them clean and in a case and always back them off to the lowest setting or to stop, don't drop them and don't use them as a breaker bar....
twowheel99 is offline
post #8 of 10 (permalink) Old 02-16-2011, 12:08 PM Thread Starter
Govdog76's Avatar
GReat info everyone. Sounds like the best single tool is the 10-100. Also good reminder about the in/lb conversion. I think even my puny brain can do that math (although metric base-10 is still easier)!
I am around Chapel Hill. We should have a local Roadie meet-up sometime (after I actually pick up my bike...)
Ian
Govdog76 is offline
post #9 of 10 (permalink) Old 02-16-2011, 02:09 PM
Ditch's Avatar
Craftsman has digitals now that you can switch between the three inlbs ft lbs and Nm. I love mine. I figured I would post to keep it NC strong.
FOR THOSE WHO CAME HOME...
FOR THOSE WHO DID NOT COME HOME...
FOR THOSE WHO HAVE YET TO COME HOME...
1997 FXD(P) STOCKISH
1999 FXSTDC TO MODIFIED TO KEEP RUNNING
2011 FLRTU just starting the mods
Zummo 665
HD Air deflectors
Sancho's wings
Cee Bailey's 14in light tint
HD hammock seat heated
HD ajustable back rest
cup holder
Jackpot 2-1-2 with SE Fatshotz
Power Vision
Ditch is offline
post #10 of 10 (permalink) Old 02-16-2011, 03:05 PM
HogWild's Avatar
Eastern NC is getting pretty strong around here.
HogWild is offline
torque wrench selection Tackdriver Tech Area 23 02-16-2014 05:41 PM
Torque wrench recommendations StriderJim Do-IT-Yourself 17 02-02-2013 11:34 PM
Torque wrench dwighop Do-IT-Yourself 14 11-12-2012 07:22 PM
in.lb. torque wrench Radioactive General Off-Topic Discussions 27 10-03-2011 09:50 PM
What torque wrench??? wachuko Tech Area 12 08-09-2011 02:35 PM
