Gas in my oil tank! Help! - Road Glide Forums
post #1 of 9 (permalink) Old 02-22-2011, 08:16 PM Thread Starter
DAWG_6's Avatar
Okay, so it's my lawnmower, but I need some advice.....My daughter was trying to help dad out with the mowing right before the season ended....and she put gasoline in the oil fill hole. Don't ask.
Besides running new oil through it several times and hand turning the motor, do I need to do anything else before I fire it up???
Thanks for any help you can throw my way.
"People sleep peaceably in their beds at night only because rough men stand ready to do violence on their behalf."
DAWG_6 is offline
post #2 of 9 (permalink) Old 02-22-2011, 08:26 PM
Govdog76's Avatar
Dawg,
Your post title is a freakout waiting to happen! lol...
Sorry to hear about your "mishap" but at least it isn't the glide. I have 2 daughters myself (2 and 4) so I am all too familiar with these types of issues. As for resolution, I will leave it to others with more mechanical savvy, but I have always found those type motors to be built like little tanks. I would bet you will be fine with the steps you have already taken.
If the motor blow, just bore the cyls, increase the stroke, and open up the exhaust. You can rebuild it as a SE mower!
Govdog76 is offline
post #3 of 9 (permalink) Old 02-22-2011, 08:27 PM
You should be good, you might want to run it at first until it warms up and change it once more while the oil is hot. Oil is cheap compared to a new mower until they get a barrel of oil back up to where they want it....
twowheel99 is offline
post #4 of 9 (permalink) Old 02-22-2011, 09:07 PM
SharkNose's Avatar
Your doing it right, just check the latest oil you removed to see if there is any gas residue still coming out. Make sure you remove spark plug to make it easier to turn engine over w/o starting.
Don't know what type of mower you are talking about, but does it have an oil filter that would need to be changed. These are normally only on much larger engines(riders) or commercial walk-behind units, but thought I'd throw that out there just in case.
When you first start it up, listen closely for any strange noises or rough running.
-If it sounds OK, I'd suggest running for 3 to 5 minutes to let entire engine block get warm without actually using it for work(under load), then change the oil one last time to make sure all internal oil passages are cleaned out.
-If strange noises, you can redo your prior steps again and hope.
And lastly, did you check the gas tank to make sure she didn't put oil in there?!? Sorry, but if so: drain & clean tank(oil will sit on bottom), check gas line filter and install new spark plug.
These (and most) engines allow some blowby past piston rings...that's why the oil gets darker. But these crude little engines normally can take quite some abuse by the average owner.
JMHO
SharkNose is offline
post #5 of 9 (permalink) Old 02-22-2011, 09:14 PM Thread Starter
DAWG_6's Avatar
That's why I love this forum....good (and humorous) advice!
Thanks for the replies....it's a new Briggs and Stratton...built like a battle axe....push mower, not even power drive....I go old school as much as possible...I don't think it has an oil filter...
I will run it, get it warm, and flush it again with new oil.....Seriously, thank you all for the assistance.
DAWG_6 is offline
post #6 of 9 (permalink) Old 02-22-2011, 10:19 PM
HogWild's Avatar
and have a fire extinguisher nearby.
"No man is rich enough to buy back his past, so enjoy the moment"
HogWild is offline
post #7 of 9 (permalink) Old 02-23-2011, 09:17 AM Thread Starter
DAWG_6's Avatar
Always!!! LOL
DAWG_6 is offline
post #8 of 9 (permalink) Old 02-23-2011, 10:43 AM
CHAINSAW's Avatar
On the plus side your daughter learned a little something about mowers and engines. A lesson Im sure she will never forget in life And,.. she probably still feels kinda bad so you can use that all this summer and sit back with a cold one and a cigar while she is mowing.
Such is the rule of honor.
CHAINSAW is offline
post #9 of 9 (permalink) Old 03-08-2011, 09:51 PM
RoadHawg's Avatar
you should be just fine, run the thing and any left over fuel will evaporate off, in fact back in the old days of radial engine aircraft there was an "oil dillute" feature that ran fuel into the oil tank to thin it out for better cold starts in freezing weather!
Mikes Hawg Paint, Camino, CA.
RoadHawg is offline
Damage to my bike from a gas station tank cover ironmark *General Road Glide Discussions/Pictures 32 10-23-2013 11:38 PM
Tank gas question, smell gas Dirty Irish *General Road Glide Discussions/Pictures 3 12-22-2011 04:39 AM
Help with gas tank/panel advice ODA CDR (RET) *General Road Glide Discussions/Pictures 13 09-02-2011 11:55 AM
Need Help. Running out of gas with 2 gallons in the tank BDMastiff *General Road Glide Discussions/Pictures 18 02-24-2011 04:30 PM
New RWD gas Tank Pork-Chop *General Road Glide Discussions/Pictures 7 05-20-2010 09:28 PM
