2010 RG fuel tank removal? - Road Glide Forums
post #1 of 5 (permalink) Old 03-12-2011, 04:28 PM Thread Starter
Wasn'r sure where to put this? Anyway:
I know how to release the quick disconnect on the fuel line at the left rear of the tanks. My question is: Is there a check valve in the tank that hold the fuel in, or will it drain whatever is in the tank from the nipple after the line is removed?
racerdave is offline
post #2 of 5 (permalink) Old 03-12-2011, 04:30 PM
black-glide's Avatar
Just remove the connection like a air tool connection, don't worry for the gaz, there are a stop valve inside
black-glide is offline
post #3 of 5 (permalink) Old 03-13-2011, 09:15 AM
dklanecky's Avatar
I'd only worry about the gas in the tank only if there's much of it, makes it a PITA to handle due to the extra weight.
73 Sporty - Sold
07 Sporty - Sold
09 Vivid Black Road Glide (FLTR) with ABS, Security, Fuelmoto Satge One, Clearview, Harley Hammock Seat, Hogg Chopps Lowers, Bright Ass Tail Light, SERG Headlight Bezel, Detachable King Tour Pak, Painted Inner Fairing, Cruising Southeasten Wisconsin, Delivered 3/6/2009:clap:
09 Black Fat Bob (FXDF) in Vivid Black of course, Delivered 5/1/2009
dklanecky is offline
post #4 of 5 (permalink) Old 03-13-2011, 09:49 AM
HD_Shock's Avatar
Haven't pulled my tank but in case you weren't aware of this ...
My 2011 service manual warns that the fuel in that line is under high pressure (58 PSI) and you risk spraying gas all over the place when you pull it. It suggests to pull the fuel pump fuse and running the bike until it dies - and then hit the starter for an additional 3 seconds. That's supposed to purge all the gas from the line. (Then it says to pull the main fuse before disconnecting the line to prevent any chance of spark - the usual precaution.)
According to the diagram, the fuel pump fuse is the 4th one down in the first column on the left.
-phil
2011 FLTRX 103
HD_Shock is offline
post #5 of 5 (permalink) Old 03-13-2011, 11:04 AM
HUmmm... i remove my gaz tank this winter, she was at the half, yes the batterie was disconned, but for another raison. I only unclip the fitting under de gaz tank. For sure the tank was heavy, but any other problem than the weigt, i replace the tank, push on the starter and the bike start at the first crank.
any good instructions to remove 2011 fuel tank to replace fuel filter? CPY84 Do-IT-Yourself 9 10-11-2016 12:31 AM
?? 2010 RG rear wheel removal ?? racerdave Wheels and Tires 7 06-04-2014 12:38 PM
Didn't someone with an 09 RG find a HD tank badge that covered the tank decal? scott *General Road Glide Discussions/Pictures 5 02-25-2011 02:09 PM
fuel tank removal Clyde Equipment-RG 3 08-21-2010 10:07 PM
