04-07 DTC Codes - Road Glide Forums
post #1 of 6 (permalink) Old 03-17-2011, 01:43 PM Thread Starter
04-07 DTC Codes
These will also work on the 08 bikes . There are additional codes for the 08 bikes not listed here .
"BUS Er" - Serial data bus shorted/low/open/high
B0563 - Battery voltage high TSM/TSSM
B1004 - Fuel level sending unit low instruments
B1005 - Fuel level sending unit high/open instruments
B1006 - Accessory line over voltage instruments
B1007 - Ignition line over voltage instruments
B1008 - Reset switch closed instruments
B1122 - Right turn output fault
B1125 - (HFSM) Left turn output short to battery
B1131 - Alarm output low TSM/TSSM
B1132 - Alarm output high TSM/TSSM
B1134 - Starter output high TSM/TSSM
B1135 - Accelerometer fault TSM/TSSM
B1141 - Ignition switch open/low
B1151 - Sidecar BAS low TSM/TSSM
B1152 - Sidecar BAS high TSM/TSSM
B1153 - Sidecar BAS out of range TSM/TSSM
P0106 - MAP sensor rate of range error CARB
P0107 - MAP sensor failed open/low CARB
P0107 - Map sensor open/low EFI
P0108 - Map sensor failed high CARB
P0108 - Map sensor high EFI
P0112 - IAT sensor voltage low EFI
P0113 - IAT sensor voltage open/high EFI
P0117 - ET sensor voltage low EFI
P0118 - ET sensor voltage open/high EFI
P0122 - TP sensor open/low EFI
P0123 - TP sensor high EFI
P0131 - Front 02 sensor low (lean)
P0132 - Engine running rich
P0134 - Front 02 sensor open/not responding
P0151 - Rear 02 sensor low (lean)
P0152 - Rear 02 sensor high (rich)
P0154 - Rear 02 sensor open/not responding
P0261 - Front injector open/low EFI
P0262 - Front injector high EFI
P0263 - Rear injector open/low EFI
P0264 - Rear injector high EFI
P0373 - CKP sensor intermittent CARB/EFI
P0374 - CKP sensor not detected CARB
P0374 - CKP sensor sync error EFI
P0501 - VSS low CARB/EFI
P0502 - VSS high/open CARB/EFI
P0505 - Loss of idle speed control EFI
P0562 - Battery voltage low CARB/EFI
P0563 - Battery voltage high CARB/EFI
P0602 - Calibration memory error CARB
P0603 - EEPROM failure CARB
P0603 - ECM EEPROM error EFI
P0604 - Ram failure CARB
P0605 - Program memory error CARB
P0605 - ECM flash error EFI
P0607 - Converter error CARB
P0661 - Intake solenoid low/open
P0662 - Intake solenoid high/shorted
P1001 - System relay coil open/low EFI
P1002 - System relay coil high/shorted EFI
P1003 - System relay contacts open EFI
P1004 - System relay contacts closed EFI
P1009 - Incorrect password CARB/EFI
P1010 - Missing password CARB/EFI
P1351 - Front ignition open/low CARB/EFI
P1352 - Front ignition coil high/shorted CARB/EFI
P1353 - Front cylinder no combustion EFI
P1354 - Rear ignition coil open/low CARB/EFI
P1355 - Rear ignition coil high/shorted CARB/EFI
P1356 - Rear cylinder no combustion EFI
P1357 - Intermittent secondary front EFI
P1358 - Intermittent secondary rear EFI
U1016 - Loss of ICM/ECM serial data instruments
U1016 - Loss of ECM serial data, vehicle speed, vehicle inhibit motion or power train security status TSM/TSSM
U1064 - Loss of TSM/TSSM serial data CARB/EFI
U1064 - Loss of TSM/TSSM serial date instruments
U1097 - Loss of speedometer serial data TSM/TSSM CARB/EFI
U1255 - Missing message at speedometer EFI
U1255 - Serial data error/missing message EFI
U1255 - Serial data error/missing instruments or TSM/TSSM
U1300 - Serial data low instruments, TSM/TSSM , CARB/EFI
U1301 - Serial data open/high instruments, TSM/TSSM, CARB/EFI
2006 models with 02 sensors ( Dynas )
P0131 - Front 02 sensor lean for any length of time
P0151 - Rear 02 sensor lean for any length of time
Above codes can also be set if 02 sensor fails.
u
post #2 of 6 (permalink) Old 10-02-2011, 07:39 PM
03 Codes
Hey,
Would you have info for the codesfor 03 Roadglide?
Thanks,
Bob
Bobglide03 is offline
post #3 of 6 (permalink) Old 07-30-2013, 08:37 PM
how would you go about seeing these codes?
TC308 is offline
post #4 of 6 (permalink) Old 12-15-2013, 12:27 AM
Biggy's Avatar
This might be a stupid question but how are you able to see these codes on any bike, mine is an '07 but I'm assuming some tool is needed.
Sincerely, Tim
2007 FLTR
Biggy is offline
post #5 of 6 (permalink) Old 12-15-2013, 11:11 AM Thread Starter
It is explained in a sticky in the troubleshooting section of the forum. https://www.roadglide.org/showthread.php?t=4439
post #6 of 6 (permalink) Old 09-01-2015, 12:31 AM
bike has engine miss
checked codes and got po107 code how repair
Capt bob is offline
Troubleshooting DTC Codes RowdyRed Troubleshooting for Road Glides 2 03-14-2018 02:13 PM
07 flh high idle with 4 codes Bob0707 Engine Related 1 04-18-2014 05:36 PM
Codes and more codes SmokeyJoe Troubleshooting for Road Glides 3 03-09-2014 01:56 PM
2010 DTC Codes ironmark Troubleshooting for Road Glides 15 06-18-2012 12:41 PM
07-09 DTC Codes ironmark Troubleshooting for Road Glides 2 04-03-2011 12:26 PM
